how do i change the thermostat? *new info added*
Old Jul 21, 2006
drunkenmagnum's Avatar
my thermostat is sticking and i must replace it.
where is it located?
how do i remove it?
is there a DYI on this?
thanks for any help!!!
Old Jul 21, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
I’m curious also.
Old Jul 21, 2006
streetglower's Avatar
All you need to do is remove the 2 bolts holding the thermonstat housing on (the housing is attached to the lower radiator hose) and remove it with the hose still attached and then remove the thermostat. Make sure you put the new one in the correct way. there is piece on the thermostat thast faces up.
Old Jul 21, 2006
02BLKCIVIC's Avatar
thank you sir!^^^
Old Jul 21, 2006
thanks as well!
streetglower to the rescue again!
just to be sure so when i do this,since my car is not here and i will not have access to a computer-
will i have to drain the radiator first and is it pretty easy to find it thermostat?
Last edited by drunkenmagnum; Jul 21, 2006 at 01:53 PM. Reason: Automerged Doublepost
Old Jul 21, 2006
02BLKCIVIC's Avatar
As soon as you remove that hose coolant will go every where.
So I would drain it...
Old Jul 21, 2006
you wont need to drain the radiator, but I am sure the coolant that is suspended in the block will come out. the thermostat housing sits in between the radiator and the hose leads up to the housing, so the fluid will stay in the radiator. just make sure when you remove the housing, that you keep it facing up to keep any fluid that is in the hose in there. if you point it down, of cource the fluid in the radiator will come out.
But when I did this, I had the coolant all drained out since I had just replaced the timing belt and water pump.
Old Jul 22, 2006
ok i changed it out and it is still overheating!! what now? should i put new fluids in it? should i try to get air out of the radiator????? what can be wrong?
how could i tell if it is the head gasket or water pump??
Old Jul 24, 2006
02BLKCIVIC's Avatar
how many mile are you at???^^^
thana
Jun 15, 2020 07:05 PM
ttharper
May 11, 2015 07:27 PM
bo_red
May 4, 2015 01:47 PM
mievil
Apr 28, 2015 11:02 PM
bsmiley
Apr 27, 2015 01:27 PM
