Catalytic converter heat shield?
Old Jun 1, 2006
form3hide's Avatar
form3hide is an unknown quantity at this point
Hey guys,
As of late, I've been hearing a very faint humming noise coming from my car when over 2k rpms and doing 40mph+. I brought it into Honda this morning. They checked it out and are informing me that the catalytic converter heat shield needs to be replaced.
I'm tight for cash (they want 190 or so for it), so I asked about leaving it on until I can afford it. They said it will cause no harm leaving it on there besides being annoyed by the sound.
Is this accurate? Should I treat this issue as soon as possible (read: credit card) or can I actually go a month or two to fix it?
Old Jun 1, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
**** it. Its a piece of thin sheet metal, its definitely not worth $190.
What the heck could be "wrong" with a piece of metal? Its rattling?
Just take it off, OR, if you look at it, there should be a big rust spot where the cat was rattling against it, take a dremel and cut a big hole around the rub spot.
Old Jun 1, 2006
form3hide's Avatar
Well, they said exactly what you said.
After time, it gets rusted/warped... and that'll cause it to make a humming noise.
They just called back and said they put some kind of screw/bolt on it (for free) and it should help with the noise.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Munzy
21
Oct 7, 2015 07:48 AM
Luluharp
Sep 27, 2015 11:56 AM
jsmithe2010
Sep 25, 2015 07:42 PM
fvckbg
Sep 8, 2015 09:55 PM
