Throttle Body Problems
Old Feb 17, 2006
Civicman1988's Avatar
I just put on my new throttle body from maxbore and my maintance light flashes until i get it into drive? Does anyone know what that means? My brother says that my new throttle body is going to screw my intake valves all up is this true? has anyone has these problems i really need help any suggestion are welcome.
Old Feb 17, 2006
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
Theres a big differance between a check engine light and your maintance req'd light. It means nothing untill you see a check engine light. Also as far as a throttle body messing up valves... Ive never heard something so dumb in my life. no offense to your brother but thats just plain stupid. And if you want to know more about your throttle body and what will eventually happen talk to pm gearbox.
Old Feb 17, 2006
thanks i thought taht sounded stubbed but i didnt say anything.
Old Feb 18, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
that maint light means get an oil change usually. so its no biggy like slow gold said.
Old Feb 18, 2006
turboengnr's Avatar
DONT PANIC
does the car idle a lot higher than normal now?
If not, dont worry about it. If it does, that means that there is a vaccum leak somewhere.
And yea, if you have a very bad vaccum leak, you can burn the valves. But if you had a vaccum leak bad enough to hurt the valves, you would definately know it.
Old Feb 18, 2006
Thanks bro it doesnt run high at all runs like at 600 whens its idling. So i dont think there a vaccum link i reset that maintance required lights.
Old Feb 18, 2006
widegts's Avatar
widegts is on a distinguished road
since wer are on the topic. I just put o my friend and it idles at 2100.. I told him to turn the car off, I double checked everything, it is all installed correctly. SoI couldnt figure it out, so I took it off, and put stock on. It works fine..What could cause this? I know it has to be on the bored throttle body or the seal to the intake manifold. Im not to sure its is the seal b/c it works fine with the stock one. Any ideas? I told my friend just to take it to honda and have them put it on, and let them deal with it. BTW the stock is on and hes not driving it around with a bad idle.
Old Feb 18, 2006
uplug ur battery over night to let the ecu rest itself i talked to a machinic and he told me to drive it with the bad idle the ecu will correct itself.
Old Feb 18, 2006
widegts's Avatar
i did. I let it reset for a few min. Isnt it bad to drive at high idle? Thats why I took it back off his car..
Old Feb 19, 2006
you always relearn the idle when swapping the throttle body. after unplugging the battery, you have to let it idle for 10 mins once the car is warmed up. its easier to drive the car first upto temp, then pull the battery for 10 secs, then start the car and let it idle 10 mins. you can't use accessories or press the gas during this time.
davidpaustin
Apr 29, 2015 02:23 PM
green01civic
Apr 29, 2015 01:36 PM
mievil
Apr 28, 2015 11:02 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
