Weird intermittent crank no start
Old Oct 7, 2022
mason29's Avatar
mason29 is an unknown quantity at this point
Hello. New guy here and Family Mechanic !! Grandsons ‘p5 civic ex 1.7 had overheated and he ran it hot ! Bad head gasket so I removed head and checked installed head ! Before the overheat problem the car would start right up ! After the head install it wouldn’t start . Crank and cam sensors have 12v ! Somewhere in the diagnosis I noticed that when I plugged my scanner into the dtc it would fire up ! If I removed the scanner it wouldn’t start ! I then received a code for intermittent crank sensor signal ! With car running and code scanner connected I went to the crank sensor code and erased it , as soon as I erased it the car shut off !! Also I did install a new crank p sensor after the head gasket/no start but remember the old sensor was fine before gasket . I cannot find a download wiring diagram so I can follow where feeds what ! Thanks
Old Oct 7, 2022
BrotatoChip's Avatar
Super Moderator
Re: Weird intermittent crank no start
Car starting only when the scanner is plugged in usually indicates a ground issue. Since you had the head removed, check all the grounds under the hood. It's possible you missed reconnecting one. Specifically where the engine harness connects to the water neck on the block near the upper radiator hose. Also the ground jumper that goes from about the same area to the radiator support.
Old Oct 7, 2022
Colin42's Avatar
Check alternator bolts as well
Old Oct 7, 2022
mason29's Avatar
Thanks I have checked under hood but haven’t seen any obvious problem but you are absolutely correct about grounds ! I am going to try and download a service/repair manual for ground points . Would you know where I can find a manual ? Agree about the head off/on then having the start problems ! I worked on a Chrysler Pacifica for literally 4 months looking for no start ! Ended up a ground wire under the tpm was in place but corroded off connection !
Old Oct 9, 2022
Colin42's Avatar
Go to the most recent link here
https://www.civicforums.com/forums/1...king-7th-gen-s
Old Oct 9, 2022
mason29's Avatar
Re: Doesn't wanna start after driven.
I’m not sure how I even got on this post !!
Old Oct 9, 2022
thetut's Avatar
thetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of light
This post's first entry defines the various grounds.
https://www.civicforums.com/forums/1...t-install.html
Old Oct 10, 2022
Super Moderator
Originally Posted by mason29
BrotatoChip I did miss the ground You mentioned by water inlet ! I actually cleaned that ground while getting ready to install the head but it got tucked down and I missed it ! Anyhow It did start right up without scanner on but still in limp ! When the car wouldn’t start after the new head gasket I figured the crank sensor was bad and replaced it with a cheap one and I am getting the crank sensor intermittent code ! I am thinking the Denso that I replaced is probably good !
You posted this an some other random thread so I moved it back here. Glad to hear you got the starting issue figured out. Yes, only use OEM sensors. Honda's tend to not like other brands.
Patrick Flores
Engine start problems
Nov 13, 2020 06:48 AM
mxchamp5
Dec 25, 2018 12:55 AM
Chbaird1994
21
Oct 4, 2018 10:56 PM
RustyShackle
Sep 27, 2018 07:47 PM
Scott Anderson
Apr 2, 2015 11:08 AM
