Radiator fan does not turn on when temp gauge goes up.
I noticed while driving today that my temp gauge would go up to touching the red line briefly and back down to normal again. I turned the heater on and when the needle goes up the air through the vents would blow cold and when the needle comes down the air would blow hot. I turned the A/C on and both fans turn but when I turn the A/C off the none of the fans would turn when the needle reads hot.
I'm thinking I would have to replace the thermostat or relay or sensor. Any thoughts?
Re: Radiator fan does not turn on when temp gauge goes up.
Probably the sensor easy to test, if you do need to replace it, don't buy a cheap parts store one
themovielife
Mar 23, 2011 06:42 AM
chairman101
South Cali
Sep 21, 2009 08:20 PM
gfHonda
Jan 4, 2008 04:33 PM
BlueRevs
May 3, 2007 07:38 PM
