Interior lights 03 Civic
Old Feb 21, 2020
Collector1's Avatar
Collector1 is an unknown quantity at this point
Interior lights work if I manually push buttons but don't work when any door is open.
Old Feb 21, 2020
BrotatoChip's Avatar
Super Moderator
Re: Interior lights 03 Civic
Do you have the switch on the dome light set to turn on with the doors open?
What trim Civic? (DX, EX, LX, etc.) Dome lights are separate from the front map lights so it's possible they burned out.
Old Feb 21, 2020
Collector1's Avatar
It is LX
Old Feb 21, 2020
Super Moderator
You should have one dome light in the center of the ceiling. That is the only light that comes on when the doors are opened (granted the switch on the light is properly set). If the switch is set correctly and the bulb doesn't come on then it has likely burned out. The plastic cover is easy enough to pop off and check.
Old Feb 21, 2020
Collector1's Avatar
You are probably right. I was thinking on my other Civic that the front lights also came on. Will check. That's be great if that's all it is! Thanks!
editundo
Feb 20, 2010 01:59 PM
xshift28x
South Cali
Apr 9, 2005 01:24 PM
Silver_JS5
Lighting
Apr 16, 2004 01:24 PM
gearbox
Feb 11, 2004 04:08 PM
