Wire harness and ecu question.. Please help asap
Old Jan 24, 2010
1.7lciviclx2001's Avatar
1.7lciviclx2001 is an unknown quantity at this point
I have a 2001 civic lx coupe... It's time to replace the engine..
Ok I'm buying a D17a2 from a 2002 civic ex.. Now I'm wondering if I have to switch the whole wire harness? Or will the one for the D17a1 work? As you know the a2 is a vtec and the a1 is not..
Also the new engine doesn't have the ecu.. What Manuel ecu should I use?
Off topic... I will probably have to replace the 5 speed transmission soon.
What transmissions will work? Will it have longer gear ratios? Please help I'm a civic noon
Old Jan 24, 2010
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
Re: Wire harness and ecu question.. Please help asap
whats wrong with the engine that u need to replace it?
also the A1 harnss should work fine. if u got a 01-02 A2 motor then it's the same minus 2 wires for vtec. if it's a 03-05 the o2 wiring will be diffrent. (wideband vs narowband.)
Old Jan 25, 2010
seoul4korea's Avatar
seoul4korea can only hope to improve
+1 agreed.
Old Jan 26, 2010
sk8nbmxr411's Avatar
sk8nbmxr411 is an unknown quantity at this point
Sense you are already planning to pay for the swap, get a better engine. Get a k20a2 instead of the slow *** d17. You will be much happier off.
Old Feb 1, 2010
Alot of the gaskets need to be replaced. Some internal problems aswell.. I can't find any k20 engines in northern Wisconsin. I found a b20, but as you know that won't fit or meet efficency specs for an 01.. The engine wAs from a 02 civic...
My civic also lost about 10 mpg so I'm driving. My moms 92 civic for now...
Why the heck does the 92 civic lx feel faster than my 01 civic lx?
Old Feb 2, 2010
[QUOTE=1.7lciviclx2001;4455414]Alot of the gaskets need to be replaced. Some internal problems aswell.. I can't find any k20 engines in northern Wisconsin. I found a b20, but as you know that won't fit or meet efficency specs for an 01.. The engine wAs from a 02 civic...
Why the heck does the 92 civic lx feel faster than my 01 civic lx?[/QUOTE]
Less restrictions?? Sounds like someone has been neglecting their civic.
Old Feb 9, 2010
only when i realized there was starting to be problems.. would a h22a1 work?
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Jon-Ohio
Jun 30, 2018 08:10 PM
01civyv3
Jun 2, 2015 05:21 AM
Aball93
May 16, 2015 10:11 AM
