Kill switch?
I Hunt Goats, Rams, And Mustangs.
Kill switch?
Any one know how to properly install a kill swtich so i can pass tech? IE: Cuts off battery and Alt, since my batt has been relocated to my trunk? A wire diagram would be great!
If you kill the main battery line, you'll kill everything.
+ battery terminal --- kill switch--- line to power harness under hood.
Right... ****, ok, other end of the remote cable. Assuming you spliced the new cable in where the old one was (the charge harness), I think there's 4 wires that come together there (battery, alternator, starter and car power?) Put in a terminal block and solenoids on the battery and alternator lines.
Did some fishing around, that seems to be one way to do it, but that sounds complicated.
Blazz
Aug 30, 2015 11:07 PM
dtdoyle
25
Aug 30, 2015 06:57 PM
Klame9420
Aug 13, 2015 06:00 PM
