Car Takes Longer Time To Start - Why?
Old Feb 14, 2005
kenji4862's Avatar
kenji4862 is an unknown quantity at this point
When I turn my keys, usually takes about 1 second to get the car started, but now it sometimes takes a good 2 seconds for it to start.
Kind of a bad explanation, usually it'll turn on after the 3rd "jujuju" sound but now it takes over 6~7 times.
Is this normal? It's been about 2 years of owning the car.
Old Feb 14, 2005
flotsamm's Avatar
Yeah its normal.. usually its the battery getting old.
Old Feb 15, 2005
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
cold?
Old Feb 15, 2005
qfinger's Avatar
qfinger is an unknown quantity at this point
Yeah, check the battery. I remember my old Pontiac was doing that until I changed the battery, then its like instant starts.
Old Feb 15, 2005
_Viper_'s Avatar
Do you put the key in the ignition before starting it??????
Old Feb 15, 2005
QBoi's Avatar
roffle
Most likely the battery or because its friggin cold.
Old Feb 15, 2005
2K1Civic17"Gabe's Avatar
spark plugs been changed? That would do it. Every 30,000 you should have them changed. You get better gas mileage afterwards as well.
Old Feb 15, 2005
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
i think he means leaving it in the "on" position for a few seconds before trying to start it, so it has time to build pressure.. or set the computer or whatever the hell doing that does...
but yeah.. could be yer battery (auto zone will check it for free) or it could be the sparkplugs... speaking of which i need to change mine sometime soon
Old Feb 15, 2005
qfinger's Avatar
WTF? Aren't the stock platinum plugs good for 100K?
Old Feb 15, 2005
Okay you guys it's not normal to take longer than 3 cranks to start. 9/10 times mine starts after 3 cranks whether it's 100F or -10F.
1. Make sure you turn the car to the ON position for a few seconds to let fuel pressure build before turning to the cranking position.
2. get a new battery, optima yellow is good, group 51
3. get new plugs. I had to replace mine at 18k miles. They were all carbon fouled. Got ngk iridium and it's been great so far. Less voltage needed = better starts.
4. Finally you can upgrade stock ground wires with 4 gauge thicker cable, but not really necessary.
Old Feb 15, 2005
starstryke's Avatar
starstryke is an unknown quantity at this point
batteries perform better in cold climates.. replace the plugs.. copper works the best but it wears out faster.. can't remember what has the best spark/life..
Old Feb 16, 2005
climacus's Avatar
climacus is an unknown quantity at this point
I think you meant perform worse in cold climates. That's why people with old junkers always find themselves with dead batteries during the cold snaps.
Old Feb 16, 2005
Metallica454's Avatar
The Beer-man
Metallica454 is an unknown quantity at this point
no no no no no. plugs should never NEED changing until 100,000 miles at least.
Old Feb 16, 2005
right..... anyway, yes in winter a GOOD battery works better. Usually during summer I find my voltage gauge reading low and everything getting less juice.
Old Feb 17, 2005
gc30's Avatar
gc30 is an unknown quantity at this point
i'm not sure waht it is but my 04 has the same problem, checked the battery and its' fine, it only happens rarely but it happens, warm or cold!!
Old Feb 22, 2005
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
ok, so i was sitting in my car today with the ignition in the on position but engine off...i ate my lunch while listening to some tunes.
when i was done, i tried to start the engine but it wouldn't start. all it did was crank. i waited two seconds then cranked again. this time i held it for about 5 seconds and the engine started.
similar thing happed to me a couple days ago. same situation. i was sitting in the car and chatting with a friend while also listening to some tunes(key in on position).
the car only has 19,000km on it but it's 2.5years old and it has been driven pretty much every day. since the key was always in the ignition for quite a long time, i'm sure the fuel pressure must have been good and the immobilizer should have recognized the key already. the same no start situations happened to the car when it was brand new but rarely occured. i wonder what's causing our civics to occasionally not start?
Old Mar 3, 2013
busbuddha's Avatar
busbuddha is an unknown quantity at this point
Re: Car Takes Longer Time To Start - Why?
Boy, I'm glad I found this thread. I've recently taken over driving my wife's 2002 Civic LX now that we bought her a new car. It has just shy of 136K miles on it and was just recently in for a regular service.
Three times today (and it just started today) it's started taking more than about a second to crank over before starting. Just long enough to make me say "Wait a sec, something's not right here." But this thread has given me some good things to look for and experiment with to sort out the issue.
Old Feb 9, 2020
Bob Vargas's Avatar
Bob Vargas is an unknown quantity at this point
It starts right away even before I get into the car... please revise your question or you get a nasty answer like mine!
Old Feb 9, 2020
Bob Vargas's Avatar
Yeah, I almost cry when I read this question... I would answer... "It started before I put the key in the ignition, so problem solve!"
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Richkid23
Apr 19, 2015 12:53 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
silvercallx
Oct 1, 2001 01:16 PM
