Regular Maintenance Post questions about regular maintenance here
Reliability of the oil indicator [solved]
Old Apr 30, 2022
civtorc's Avatar
civtorc is an unknown quantity at this point
Hi,
I've always assumed that the oil indicator was governed by mileage rather than the state of the oil, and that was confirmed for me last week. After an oil change, the indicator still said 10%; the mechanic said he had indeed changed the oil, and just needed to reset the indicator. But that got me wondering - how reliable is that indicator? Do I need to start checking the oil before the indicator gets toward 10%? And/or am I changing it too early if I trust the gauge?
Thanks.
Old Apr 30, 2022
FRSam's Avatar
Click Here
Re: Reliability of the oil indicator
I do mine at 3k miles regardless of what the indicator tells me. If I listened to the indicator, I'd probably be doing it closer to every 15k miles. I'm guessing the previous owners listened to that because it now burns oil.
I suspect it's more accurate for the newer cars, but I still stick to the 3-5k range, given that I do drive my car relatively hard, and I don't drive as much as I used to anyway.
Old May 1, 2022
GolNat's Avatar
Prelude Owner
Best way to know the health of your oil is to send it out for analysis. I use the minder in my Pilot and have had the oil sent out after 8–10k miles and the oil was fine. The minder doesn’t “test” the oil but rather make a estimated guess on its condition based off your driving habits.
Old May 1, 2022
GolNat's Avatar
Prelude Owner
I use black stone labs for my oil analysis’.
https://www.blackstone-labs.com
Old May 2, 2022
BrotatoChip's Avatar
Super Moderator
Use full synthetic oil if you're going to follow the maintenance minder. Conventional oil should be changed every ~3k miles, the minder would expect it to go ~10k.
Old May 2, 2022
civtorc's Avatar
Thank you all; much appreciated.
jakeconnor
General 8th & 9th Gen
Oct 19, 2021 09:36 AM
MizKJG
Jan 6, 2019 02:55 PM
honkeydonkey
Electrical
Apr 26, 2015 08:27 PM
gilloz
Oct 12, 2007 12:28 AM
