Moonroof stays open partially [solved]
Old Jan 31, 2023
Cyberterp's Avatar
Cyberterp is an unknown quantity at this point
Moonoof will open halfway, won't open fully, won't tilt. When closing, closes, then opens itself about 3 inches. It happened after I used remote start, and fumbled with the lock a few times, cuz i couldnt hear the beep from my room.
Came outside, and 3 windows were fully opened, and moonroof was open a few inches. Windows shut just fine, but not moonroof. Help, cuz were expecting another storm soon.
Old Jan 31, 2023
Colin42's Avatar
re: Moonroof stays open partially [solved]
There's a spot to manually crank it closed, there's an Allen wrench thing in the toolkit in the trunk
Old Feb 1, 2023
Cyberterp's Avatar
Thank you for responding. Good to know for the future. I tried all the elec reset suggestions no go. Then I did the opposite of what I did when I used the remote start. I had hit "lock" a number of times cuz I didn't hear the beep, then pushed remote start. It started. But when I went out, 3 windows were all the way down and moonroof was partially open.
So I sat in the car, hit the lock button on the fob once then hit the remote start button about 4 times, pausing in between. The opposite of what I did in the morning.
It worked!!!
Old Feb 1, 2023
Colin42's Avatar
Re: Moonroof stays open partially [solved]
Glad you got it closed
ernest64xp
Electrical
Mar 1, 2021 02:53 PM
quattro
Jul 7, 2009 10:42 AM
DjRags
Jul 31, 2006 09:21 PM
Ronin
44
May 9, 2003 03:04 PM
Mex
Feb 1, 2002 07:46 PM
