General Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
2019 Honda Civic EX fuel efficiency issues
Old May 25, 2020
Ktownguy's Avatar
Ktownguy is an unknown quantity at this point
Hey guys!
i have a new 2019 civic EX which as krept up to 10.4L/100kl, it used to be around 8.3-9.3, depending on econ mode on/off. Now tho, even with it on doesn’t make a difference and stays on 10.4. I had oil recently changed and its still at %70. Just had winter tires removed and summers put back on by Honda.
any idea’s to what’s sudden caused this? Or anyone else getting the same L/100kl ?
thanks!
Old May 25, 2020
Colin42's Avatar
Re: 2019 Honda Civic EX fuel efficiency issues
Check tire pressures, brakes might be dragging, air filter clogged up?
Old May 25, 2020
Ktownguy's Avatar
thanks, I called Honda and booked an appointment for Thursday. Hopefully they will check all that
Old May 25, 2020
typically it happens when maintenance is neglected in new cars.
That said, did you calibrate the tire pressures when you changed back from snow tires?
Also, moved thread to mechanical issues section, 10th gen section is for things car spec related.
hamzashakaa
General
Nov 9, 2019 03:46 AM
luisatking
Apr 4, 2013 03:09 PM
madflyer72
Mar 24, 2008 10:59 AM
Tnsmongoose
South Cali
Jan 11, 2008 08:29 PM
mikedarippa
Engine Swaps
Apr 22, 2004 06:33 AM
