h&r with koni or coilover?
Old May 16, 2003
ddongs's Avatar
ddongs is an unknown quantity at this point
I am planing to buy coilover or koni shock...
Currently I have H&R sport with blown shock....
I was planning to get tein ss coilover in the first time but i found out that they have one year limitted warrenty while koni has lifetime...
I am planing to get 17" rims and factory body kits later...
so.. would it fit fine with h&r and koni????? or should i go for coilover for the best look????
and I am also wondering about the quality of ride and handling...
would there be much difference????
if koni with spring will do fine, I will probably get koni very soon since autobas has free install promotion...
i need you guys opinions..
anyways, does anyone know the coilover with lifetime warrenty???
and i also heard that coilover is illegal... in bc...
one guy got caught for having coilover in vancouver... is it true??
Old May 16, 2003
AznSaint's Avatar
AznSaint is an unknown quantity at this point
you said koni offers life time warrenty........
would you have to apply for it.. through koni? or lets say you purchase koni at autobas for example... would you get lifetime warrenty with them???
Old May 16, 2003
ddongs's Avatar
i am sure... but i saw from the website that it is lifetime warrenty....
am i wrong?
it won't hurt me much for applying for it.
Old May 16, 2003
AznSaint's Avatar
ic.
i'll check it later when i have more time.. to read through the whole thing
im not saying its a hassle to apply through koni, but most likely.. if anything does happen with the koni's, you will most likely have to take 'em off the car..... and then send it to koni themselve.
unless they send me to an authorized koni body shop/mechanic.. and have them fix it... either way, your car will be sitting for at least a week or two 'cause they'll take forever to fix 'em.
i think the warrenty aint that much of a concern to me.. as long as the product is reliable.
Old May 16, 2003
AznSaint's Avatar
you said you have blown shocks? you're not covered with honda no more?
mine was blown also.. but i just got them replaced by honda. haha.. figure i'll get a new set of honda shocks and then buy aftermarkets... jsut in case i'll ever need the stock shocks again.
Old May 16, 2003
ddongs's Avatar
my warrenty is gone now...
my car has 84000km on it... no more warrenty...
things start to break up..
Old May 16, 2003
iamfob's Avatar
iamfob is an unknown quantity at this point
well if u go with Koni then you have to cut the front inserts and you have to use koni forever
but teins can be swap out the stock shocks and dont require to cut anything.
Old May 16, 2003
maxEmus's Avatar
a.k.a incamus
maxEmus is an unknown quantity at this point
you guys with blown shocks. how long did the stock shocks last?
and how do you go about getting honda to replace it?
what year are your cars?
Old May 16, 2003
ddongs's Avatar
i have droven my civic for about 2 years and had spring for about 6 month..
however, i think that my shock got blown before i installed my spring...
Old May 16, 2003
AznSaint's Avatar
it about eight months for my front shocks to leak...
i went for an oil change.. and honda said my front shocks was leaking... so they replaced them.
they'll only replace them if you're still under warrenty.
i dont know how the warrenty thing is. i think its 3years/60clicks if you didnt buy any extended warreenty
2002 model
Old May 16, 2003
ddongs's Avatar
is it replacing just shock or actual suspension part???
i thought that since my shocks are blown, i have throw it away anyways...
Old May 16, 2003
GaGu's Avatar
GaGu is an unknown quantity at this point
how bout JIC coilovers, less expensive than teins but just as good!
Old May 16, 2003
kFanghe's Avatar
kFanghe is an unknown quantity at this point
I got H&R's, after the install I found out that I had one blown shockg . I could either put all the old spring back in and bring it back to Honda or just replace all four with koni yellows. I think I'll go with Koni's. And I think Koni's are better than Teins.
Old May 17, 2003
iamfob's Avatar
i wish they replace the leaking shocks even our car is lowered but they wont do it
they only do it for car that never been lowered
Old May 17, 2003
Sunapollo's Avatar
Sunapollo is an unknown quantity at this point
Definitely go with Koni + HR ... because I am running on them and I'm very satisfied !
Old May 17, 2003
ddongs's Avatar
Sunapollo, do you find any problem with koni???
i heard that koni makes some noise while turning... from the gap between koni and old part...
if you don't have any problem, can i ask where you get it installed??
and how much would it be?
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
EM_WON
Jul 22, 2015 06:49 PM
