Brembo Cross Drilled/Slotted Rotors
Old Apr 16, 2003
XxJDMCivicxX's Avatar
My friend can get me them for 165$ CAD shipped to the door I'm looking for new rotors, this a good price? And anyone have suggestions on pads?
Old Apr 16, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
165 for a pair?.... if so, then that's a good deal..... i was looking for them, but had no luck so i went with the powerslots......
Old Apr 16, 2003
AzimuthX's Avatar
AzimuthX is an unknown quantity at this point
Definately a good deal if its a pair... because blanks go for $70 each.
Old Apr 16, 2003
Ya its for a pair.
Old Apr 16, 2003
AzimuthX's Avatar
Set up a group buy
But than theres no need for Cross Drilled...
Slotted is sufficient.
Old Apr 16, 2003
MediumRare's Avatar
MediumRare is an unknown quantity at this point
Can U get one more pair of the rotor for me pls =P
Old Apr 17, 2003
ill give him a call tommorow about GB but not sure how many he has left as of now but ill definitively look into for you guys.
Old Apr 17, 2003
FlippedOut's Avatar
FlippedOut is an unknown quantity at this point
im interested...
how big are the rotors???
sometimes you shouldn't get too big a rotor because our cars dont go fast enough to generate enough heat for those big rotors....
Old Apr 17, 2003
AzimuthX's Avatar
Yes and that you don't necessarily need Cross Drilled Slotted Ventilated Rotors, hey at least it won't warp as fast!
Old Apr 17, 2003
maxEmus's Avatar
a.k.a incamus
maxEmus is an unknown quantity at this point
seriously find out if you can GB that, im interested!
Old Apr 17, 2003
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
I'm very interested... set it up!!! Lemme know pls.!
Old Apr 17, 2003
Bluelle's Avatar
Bluelle is an unknown quantity at this point
i think andoy has a pair of these....u can ask him how they are......
Old Apr 17, 2003
watewate's Avatar
watewate is an unknown quantity at this point
it's a bloody Brembo for crying out loud. it's not going to warp. it's not like a shop taking a drill and making holes on a rotor.
Old Apr 17, 2003
The rotor sizes are the same size as stock ones. He sent me a pic. Right now he has them on ebay for 98$ USD buy it now, there's a couple days left he said after that he will call me for a possibel GB.
Old Apr 17, 2003
BIG's Avatar
BIG
let me know if there is a group buy
Old Apr 17, 2003
R1Style's Avatar
**** I need more money!!!
Old Apr 17, 2003
AzimuthX's Avatar
What is the stock size BTW?
Waterwater: Brembo rotors do warp!
Old Apr 17, 2003
vicLX's Avatar
<--That really is ME
Why dont you just get the KVR... i heard that they are BREMBO's Canadian Counterpart....
I got the rotors and pads for under $$250... and they workGREAT!!!!!!!!
heres a pic
Old Apr 17, 2003
1982's Avatar
1982 is an unknown quantity at this point
Re: Brembo Cross Drilled/Slotted Rotors
probably a brembo knockoff, where they buy blanks and then resurface/repackage them. anyway, cross drilled rotors suck bad. good pads would be those ones called "redstuff" i forgot which company makes them.
Old Apr 17, 2003
redstuff? what about greenstuff?
Old Apr 17, 2003
AzimuthX's Avatar
Type that in google, some say its ****, some say its good.
Old Apr 17, 2003
Mystix's Avatar
Mystix is an unknown quantity at this point
i'll be interested if they are real brembos. I was looking around and best i can find is 250/pair, not sure if they come with pads but doubt it
Old Apr 17, 2003
BJAI's Avatar
BJAI is an unknown quantity at this point
viclx: where did you get your KVR $250 rotor and pads
is that a pair? that's pretty cheap.... how good are they..
because i need to invest some money on brakes...real soon...
anyways if there's a group buy for this brembo one..
count me in..
Old Apr 17, 2003
watewate's Avatar
you make it sound like every cross drilled and slotted rotor warps.
most of the time, it's how you put it on.
Old Apr 17, 2003
AzimuthX's Avatar
Okay fine we'll drop that...
Installation is a vital key to prevent warping, TORQUE THE ROTOR properly! Also remember to break-in.
Old Apr 17, 2003
iamfob's Avatar
iamfob is an unknown quantity at this point
that's so sad if a shop actually do that and sell it to dumb ricers and claimed they are the real brembo cross drilled
hahhahhah so Ghetto
good one
and azimuthX is the man....he thinks he knows so much about 7th gen civic
his knowledge on 7th gen > me (i think)
anyway that's good price on REAL Brembo Cross Drilled
definitely setup a GB on this and i am sure a lot of can east members will be all over this GB
Old Apr 18, 2003
1982's Avatar
from tirerack.com:
"EBC Redstuff Sport/Track disc brake pads are designed for heavier sports cars, coupes and sedans used for fast high performance road driving and “track days.” as well as some race applications for light and medium weight vehicles. EBC's semi-metallic Redstuff formulation is a true asphalt race pad with a medium lifetime.
EBC Redstuff pads (friction level of 0.3µ) used on the street will feel more like standard original brakes (typical friction level of 0.25µ to 0.35µ). EBC Redstuff pads offer high resistance to brake fade and a friction level that steadily rises with temperature to reach 0.33µ at 1380° Fahrenheit. This makes them appropriate for extreme high speed driving and repetitive heavy braking use, as well as, for racecars. Redstuff brake pads provide longer pad life than Greenstuff brake pads under extreme conditions with virtually no brake rotor abrasion and wear.
Features and Benefits of Redstuff
Friction co-efficient starting at 0.3µ and rising to 0.33µ once warm
Medium initial bite with friction steadily increasing with heat
Heat stable to an incredible 1380° Fahrenheit
Low disc abrasion
Brake pads are wear items and as such, should be inspected regularly and replaced as necessary. Pads should be replaced when approximately 1/8” of friction material remains on the steel backing plate. Drivers who participate in track days should always take spare pads to the track."
redstuff > greenstuff
i think 120 mph qualifies as high speed like said high speed above.
Old Apr 18, 2003
AzimuthX's Avatar
hahhahhah so Ghetto
good one
I try not to think that because I don't.
I'm just here to PW and make friends, not enemies okay IAMFOB? Sorry if I've offended you?
Old Apr 20, 2003
R2FRESH's Avatar
R2FRESH is an unknown quantity at this point
tell me about it
Old Apr 20, 2003
Narc's Avatar
Narc is an unknown quantity at this point
Sounds like a great deal for a pair. My 2nd biggest complaint of the 7th gen was the brakes. Get aggresive on those brakes, and they wobble all over the place. No confidence in them.
I'm definately in for a group buy.
