re: bodykit theft
Old Mar 13, 2003
HIGHLYreflective's Avatar
HIGHLYreflective is an unknown quantity at this point
re: bodykit theft
add on front/rear lips and sideskirts are ridiculously easy to steal off a car. in most cases all you have to do is unscrew 4 or 5 screws and boom, off it comes. it took me less than 5 minutes to take the front lip off my cousins 2k2 coupe, i timed it myself, just to see how long it would take for a would be thief. i want to know if there is a way to put them on so it's impossible or extremely difficult to take off. a friend of mine that owns a veloz had the entire skirt package stolen off his car one evening when he parked it outside a movie theatre.
Old Mar 13, 2003
netcbc's Avatar
netcbc is an unknown quantity at this point
yeah i was thinking the same thing when i put on my tsunmai lip, thats why i got a pager alarm, not that its 100% safe but much safer then b4
Old Mar 14, 2003
Booohahaha's Avatar
BAD MON
if u want that sucker to stay on
use some silicone haha
its gonna damage the lip if u try to rip it hehe
Old Mar 14, 2003
Macko's Avatar
Macko is an unknown quantity at this point
best way is to mold the damn thing on.. but in your case.. silicon on it and add more screws or hidden ones
Old Mar 14, 2003
O1Coupe's Avatar
O1Coupe is an unknown quantity at this point
Yeah custom drill some holes with a drill... that'll stop those bastards.
Hmmmmmmmmmmmmmmm... did you say you can uninstall side skirts in 5 minutes?? [IMG]i/expressions/demon.gif[/IMG]
Old Mar 14, 2003
FlippedOut's Avatar
FlippedOut is an unknown quantity at this point
how much to mold the kit on?
does it require a full body paint job?
does it really matter to make custom drills, because they'll just find the extra drilled holes and take what they want???
Old Mar 14, 2003
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
Quote
[hr]Originally posted by: FlippedOut
does it really matter to make custom drills, because they'll just find the extra drilled holes and take what they want???[hr]
yes it does... instead of them taking 5 minutes, it'll take them 6 minutes with extra screws. J/K
No, if you hide those extra screws then it's pretty safe.
My suggestion is to put either cement glue on the head of each screws so they can't even unscrew them. Or you can put silicone, much like the one for your headlights.... so you can patch up the part where you insert the screw driver. Na'mean?
Old Mar 14, 2003
Sunapollo's Avatar
Sunapollo is an unknown quantity at this point
I will choose to mold it if that's not too expensive ...cleaner look !
Old Mar 14, 2003
thats why you buy front and rear bumber replacements and NOT lip add ons.
Old Mar 14, 2003
iamfob's Avatar
iamfob is an unknown quantity at this point
but not too many company make the full bumper replacement for our car
Old Mar 14, 2003
Booohahaha's Avatar
BAD MON
Quote
[hr]Originally posted by: CUE2k1
Quote
My suggestion is to put either cement glue on the head of each screws so they can't even unscrew them. Or you can put silicone, much like the one for your headlights.... so you can patch up the part where you insert the screw driver. Na'mean?[hr]
dang thats like a permanent thing isnt it??
hahaha crazy!!
Old May 20, 2003
bamb00's Avatar
What do you hate the most when you reach your hands under a table or a char? An old gum! Drill the hole and use all the different sizes and shapes of the screws you can find. I.e., phlips screw, robertson screw and flat screw with different sizes. After all that, stick some gum on top of the screw so if one tries to reach it, guess what they'll touch and think...
Old May 20, 2003
FurBall's Avatar
FurBall is an unknown quantity at this point
Gum? Gum turns hard after awhile.... not really useful.
I'm thinking instead of using the usual screws, install some bolts with NUTS on the inside of the lip. It'll be one helluva fun time trying to unbolt the lip, when you want to or for a thief... To make it even more fun, add multiple bolts... i.e. a 2 inch bolt, with like 5 nuts
Or, silicon with that as well would be a good idea...
Molding on a lip is a good idea, but it's alot of dough just to consider it as a theft deterrant. Molding on a lip requires at least bondo, sanding, and a paint job...... That's alot of money.
Old May 20, 2003
AznSaint's Avatar
AznSaint is an unknown quantity at this point
if ppl think there are four or five screws.. they'll eventually try and rip it off... not knowing there's another hidden screw, so one way or another... if you have that hidden screw or not... that lip kit will be stolen and damaged.
but i guess damaged is better then stolen O_O
Old May 20, 2003
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
Yeah I would recommend putting clear silicone to your body kit as well. I have it on mine, it may prevent the thief an extra minute or two but also adds extra stabiliity and strength to the kit from coming off. Highly recommended.
Old May 20, 2003
Macko's Avatar
just hope the people who intend on taking dun get aggrivated,, because they can't take it, next thing you know they are pissed and mash up your car
Old May 21, 2003
Popkorn's Avatar
Popkorn should not be trusted
you could always slam your car really low, so no one can get under your car.
Michelle2006
Sep 19, 2015 06:09 AM
Cristo
Jun 13, 2002 10:08 PM
civicdeveloper
Jun 12, 2002 07:10 AM
HeartbreakkiD
May 22, 2002 11:01 PM
