cONDENSATION IN headlights
Old Feb 14, 2003
HIGHLYreflective's Avatar
HIGHLYreflective is an unknown quantity at this point
I noticed some condesation in one of my headlights...there are no cracks in the glass. I think it was caused by the heat from baking the paint on my fender last summer after I had it repainted. If I leave it like this will the light be ok? It won't burn out will it?
Old Feb 14, 2003
AnGeLdeLsOL's Avatar
AnGeLdeLsOL is an unknown quantity at this point
Well, there is a chance, but most likely there is a crack possibly from the....
dammit...what do you call that??
the sticking thing!.........damn................you know what Mono is right?
Well, if you know, you should check the creases in between those, cause there should be a possiblity.
did you ever take your headlights apart?
Old Feb 14, 2003
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
yeah dude, if you cleared your headlights then it's because of the silicone that you used to seal the headlights together. It happens to alot of people. YOU ARE NOT ALONE! I suggest you re-seal those headlamps.
Old Feb 14, 2003
Liro's Avatar
Back from the dead
yeah, if you did clear them before, then take them apart again, blow dry all the moisture out and reseal it well.....i had to do this twice til i got it right.....if you didnt clear em, take it back to the dealership.....i wouldnt suggest leaving them the way they are....if anything, it looks nasty
Old Feb 14, 2003
Sunapollo's Avatar
Sunapollo is an unknown quantity at this point
Yeah most likely because of the seal ...
that's why when I cleared my gf's light housings ... I seal twice to make sure there's no opening at all
Scout1
Oct 5, 2015 01:33 PM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
