Wiring amp and sub
Old Jan 31, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
Wiring amp and sub
can i use 8 guage wire from amp to sub?i have a 2 channel pioneer sub output 300wrms bridged, and a inifinity kappa perfect 12 rated 350wrms, if not 8 guage, what guage wire should i use?thanx[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 31, 2003
OyD's Avatar
OyD
OyD is an unknown quantity at this point
i have 2 perfect 12s and an MTX6500D. i use 12 guage wire. 8awg is pretty thick for speaker wire
Old Jan 31, 2003
thanx, u think 300wrms amp is good for this sub?i know im not pushing it to limit, but is it decent?i know ppl push 500wrms with these subs, and is it better to get the terminal(those connector behind the box), or just drill hole on box and connect the amp wires to sub directly?[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
and is it recommend to use banana plug for the sub? or just tighten the wire is good enough?[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 31, 2003
zoooh's Avatar
zoooh is an unknown quantity at this point
If you don't have speaker terminal it'll be impossible to make it air tight unless...
- you have inverted configuration..
- you have ported box and running wire through your port. (I never seen anyone doing this...)
Old Jan 31, 2003
it might sound cheese, but cant i use something to stuffed the hole, than put tape on and than cover it with carpet to make it air tight?
Old Jan 31, 2003
zoooh's Avatar
Well I never built a box by myself before... but I know this... If you are making sealed box it has to be sealed VERY GOOD.
Decent speaker termial costs only few more bucks than a roll of duct tape so I would go with speaker terminal.
Old Jan 31, 2003
B18B's Avatar
B18B is an unknown quantity at this point
get the terminals tonight
sch2cm
Jul 21, 2015 09:58 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
robbie374
Jul 7, 2015 02:56 AM
