Factory Turbo Cars
Old Aug 11, 2002
Unstoppable's Avatar
Unstoppable is an unknown quantity at this point
Factory Turbo Cars
Ok this might be a dumb question but it has been boggling my mind for awhile now. Why is it if I see a factory turbo car on the road (GTI, Porsche, WRX), i can't hear the psssst noise, but on aftermarket cars the BOV noise is more noticable? Is there something different that I'm missing from a factory set up turbo from say an aftermarket one?
Old Aug 11, 2002
netcbc's Avatar
netcbc is an unknown quantity at this point
actually i can hear it on a wrx and 1.8T
Old Aug 11, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
cause the turbo is not big enough..and no blow off value..in factory turbo..
Old Aug 11, 2002
You sure those cars don't have BOV stock 1028?
netcbc- I guess i'm deaf than
Old Aug 11, 2002
1028CiViC's Avatar
i can hear from a 1.8t...cause my friend has golf..and can hear...
but not too attractive..
Old Aug 11, 2002
FlippedOut's Avatar
FlippedOut is an unknown quantity at this point
i once saw this black supra at one of those sgr meets...
dang that was memorable..
PSSSSsssssttttt!!!! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Aug 11, 2002
1028CiViC's Avatar
haha..of course man...twin turbo..hahahahahhahahha
u know what...this civic was white 2k1 had a big wing was
tail gating me..on hwy 7 i thought it was u....
Old Aug 11, 2002
DragonAce's Avatar
DragonAce is an unknown quantity at this point
had an '84 Ford EXP turbo once..
no blow-off valve on it..
never seen one on the earlier SVO Mustangs either..
and a bud had the '87 Grand Nat twin turbo/intercooled..again, no BOV's..
Old Aug 11, 2002
1028CiViC's Avatar
yea..only when u have a bov than it'll be easier to hear..haha..
but it will get annoying....
Old Aug 11, 2002
Bluelle's Avatar
Bluelle is an unknown quantity at this point
u usually can only hear them at high Rpm's
Old Aug 11, 2002
vicLX's Avatar
<--That really is ME
the turbo's not big enough and 1028 is right most factory turbo's DONT have BOV's
Old Aug 11, 2002
FlippedOut's Avatar
Quote
[hr]Originally posted by: 1028CiViC
tail gating me..on hwy 7 i thought it was u....[hr]
hehe...
how did you know it wasn't me?
lol
sorrry, us white civics like to tail gate people...!!! haha... j/k
Old Aug 11, 2002
andoy's Avatar
andoy is an unknown quantity at this point
because............ the factory turbo charged cars.. like the wrx proche and GTI... have a BY-PASS VALVE instead of a blow off valve.......
by-pass releases excess pressure VIA intake... so it goes back to ur throttle body.....
blow off releases excess pressure VIA atmosphere (it just comes out of a valve HENCE the noise ppppppppssssssssssssssshhhhhhhhhhhh)
Old Aug 11, 2002
andoy's Avatar
Quote
[hr]Originally posted by: vicLX
the turbo's not big enough and 1028 is right most factory turbo's DONT have BOV's[hr]
does not matter how big ur turbo is........
excess pressure will still be realeased... no matter what.....
Old Aug 11, 2002
Booohahaha's Avatar
BAD MON
change to a bigger turbo then put the BOV ..from apex'i hehehe (twin chamber blow off valve) &lt;-- sounds agressive [IMG]i/expressions/demon.gif[/IMG]
Old Aug 12, 2002
EGviNNY's Avatar
EGviNNY is an unknown quantity at this point
andoy knows his stuff!
What I can't stand right now are people putting BOVs on any stock turbo car and I mean STOCK internals. They do it just for the noise... it's a cool sound 'n all, but if you're running fully stock internals and boost, there is not enough excess pressure generated by your engine to release into the atmosphere and in the end, you're actually loosing speed between shifts because the turbo has to re-spool and make up for the loss. As for the whirling or whistling noises a turbo engine makes, most stock cars come with Silencers from the factory, not every person with a WRX wants to hear that noise everytime they step on the gas. Just like an intake silencer, they are removable and then you can kind of hear the turbo spool haha. Anyways, thats my beef o' the day .
Old Aug 12, 2002
vicLX's Avatar
OH man.... in my face[IMG]i/expressions/laugh2.gif[/IMG]
Old Aug 13, 2002
andoy's Avatar
bwahaha......... HAIL VIClx bwahahah...... dont mind me..... just wanted to use the new icons...... bawhah
Old Aug 13, 2002
Toronto's Avatar
Toronto is an unknown quantity at this point
All turbocharged engine, in order to prevent overboosting when you let off the gas pedal, uses a device call BOV to relieve excess pressure away from the high pressure zone. Normally this excess air is vented back into the intake before the turbocharger, allowing measured air to be taken account of for fuel requirement. If this mass of air is released to the atmosphere without proper compensation to the engine management system you have a unncessary rich condition, the result is wasting gas, loss of power and more pollution to the environment.
A good BOV should stay closed (not venting) until the threshold, however, many factory units are found to be "leaking".
Other than a BOV there are anti-lag devices that automatically dump excess air & fuel when you let off throttle to prevent the turbo from slowing down. The only downside is the turbocharger won't last more than a couple days when you do this.
The wastegate achieve the same result but by by-passing hot exhaust gas away from the turbine.
Old Aug 13, 2002
Correct me if I'm wrong, but the Best BOV's don't make that noise right? I mean...if you are releasing excess pressure via the atmosphere, that just means your turbo has to spool again, therefore more turbo lag. But a good BOV should hold boost the longest or something along those lines right?
Is by-pass the same as wastegate? They seem similar in function base on Andoy's and T.O's definitions. Also, if excess pressure is sent back to the throttle body via bypass, isn't that pressure extremely hot? It prolly gets cool again through the intercooler before it gets sent back again though right?
Old Aug 13, 2002
1028CiViC's Avatar
If the turbo is not big enough .. your blow off valve can't make the psh sound as loud.
i've seen a guy with A4 1.8t turbo is not big enough..so the sound is weaker..not as loud..has a blow off valve.... and WrX holy........the bov is wicked..but it gets annoying..hahah
Old Aug 13, 2002
andoy's Avatar
ohhhhhhhhhhhh well.............. I GUESS we can just keep on dreaming of having a more powerful engine......
Old Aug 13, 2002
Booohahaha's Avatar
BAD MON
Quote
[hr]Originally posted by: andoy
ohhhhhhhhhhhh well.............. I GUESS we can just keep on dreaming of having a more powerful engine...... [hr]
*pounds on table and slaps andoy*
SWAP SWAP and then TURBO hehehe
Old Aug 13, 2002
CiViCBoY's Avatar
CiViCBoY is an unknown quantity at this point
Never stop dreaming......
CarStuff
Dec 6, 2020 12:52 PM
usajags84
15
Aug 19, 2015 03:12 AM
cloudguy
Apr 28, 2015 05:02 AM
F1wanabe
Apr 27, 2015 11:06 PM
cdt12271
Apr 23, 2015 11:36 AM
