Which gas do you all use/prefer?
Old Jul 8, 2002
L23Tan's Avatar
L23Tan is an unknown quantity at this point
A lot of ppl use many different stations and grades of gas, and I was wondering is there really a noticable difference in performance when you use a higher grade gasoline, such as Sunoco's Ultra 94? Many ppl say Sunoco is the best gas to use cuz it burns better/cleaner, less emissions, highest octane available, no MMT (Manganese), has a natural gas line anti-freeze, low sulphur... etc etc. I just want your opinions, cuz I filled up today for the first time with Ultra 94 and I want to know if it's really worth using the higher grade gas. Also, don't say u only use a certain gas station cuz of points or air miles (which is what I go for)... but... I want opinions on a "performance" basis... thanks!
Old Jul 8, 2002
GuSTo's Avatar
GuSTo is an unknown quantity at this point
i always use shell bronze.....haha
sorry, i can't help you [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 8, 2002
iamfob's Avatar
iamfob is an unknown quantity at this point
i alway use Sunoco regular (87)
Old Jul 8, 2002
Machina's Avatar
Machina is an unknown quantity at this point
actually Petro Canada is the best...it has an engine cleaning additive in it...plus it's made in Canada...it really is what you should be using...and 87 octance is what's best for our engines...sure the higher octance might give you a little boost, but not really, but it costs more and you use more of it...so I suggest sticking to 87 octance at Petro Canada...
Old Jul 8, 2002
oldskool's Avatar
oldskool is an unknown quantity at this point
i always go to esso!!
only go there becuase my friend has a speedpass for hiss work, and i got a key....i fill up for free alot...
........thats why i go to esso
Old Jul 8, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
i usually go to petro canada to fill up anywhere i am or to ESSO nothing else ......i use the middle one all the time just because it has that cleaning stuff in it and i have always use it on any car i drive .......it doesn't do nothing but does make me feel better it's only an added dollar on the final gas price so it's nothing too big
Old Jul 8, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
sunoco 94
Old Jul 8, 2002
Booohahaha's Avatar
BAD MON
i use esso or shell or sunoco
doesnt matter what ever is near
87 or 89 for me!
Old Jul 8, 2002
SurrealCivic's Avatar
SurrealCivic is an unknown quantity at this point
Sunoco Regular.. I heard that it's really clean gas, and the higher octane is better for your car and the environment around us [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Machina, tell me more about the Petro Canada stuff..
Old Jul 8, 2002
Bluelle's Avatar
Bluelle is an unknown quantity at this point
i use 87.........getting hp gains off higher octane levels is just all rumors.......its doesnt do much.....
Old Jul 8, 2002
silverride's Avatar
silverride is an unknown quantity at this point
NEVER fill ESSO gas, it was tested and found to be the worst gas because of the high sulfur content.
They found that SUNOCO had the lowest Sulfur content.
Old Jul 8, 2002
wooman's Avatar
wooman is an unknown quantity at this point
I use Sunoco Regular too... but I've heard that if you fill up with Ultra94, you get better mileage... but the costs are about the same, just that you fill up more frequently with regular, and less frequently with ultra94... but I haven't tried myself since gas prices are so high... [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Jul 8, 2002
1llmatic's Avatar
1llmatic will become famous soon enough
i use 87. i've tried 94 and the rest...94 does seem to make a difference but i've been told that its not good to use high octane gas on a car meant for lower octane gas...
Old Jul 8, 2002
ice2000's Avatar
ice2000 is an unknown quantity at this point
well ...my closest gas station to my home its..shell so i always use shell gold gas
Old Jul 8, 2002
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
Esso or Petro Canada premium gas...
Old Jul 8, 2002
stillmatik23's Avatar
stillmatik23 is an unknown quantity at this point
sunoco....94
Old Jul 8, 2002
rice4foo's Avatar
rice4foo is an unknown quantity at this point
i use the cheapest one at sunoco
Old Jul 8, 2002
SkyGorGor's Avatar
SkyGorGor is an unknown quantity at this point
Tis was taken from another message board:
haha, an intake and muffler will never change your car's fuel requirements from regular to premium fuel. Unless you play with the timing or compression ratio, no higher octane fuel will go hand-in-hand with better performance. Spend a few hours and do some quality research. Those who have are telling you to stick with 87. You may think you KNOW it makes an increase in performance but in a Protege5 I guarantee it is the placebo effect you are feeling.
You are going to believe what you want but if you or anyone else actually cares about what is best for their car, they will research it and discover that regular will burn cleaner and leave less hydrocarbon build-up than premium in a new, low compression vehicle. Octane prevents early ignition(knocking) thus raises the threshold of spontanious combustion by pressure alone. This also means that your normal engine will not as easily ignite and completely burn off a premium octane fuel than a regular octane. So it is wasteful and leaves more residual carbons to build-up and slowly clog parts of your engine. Also, a lesser combustion will result in less pressure created and thus less power.
Basically, if you raise the octane, you need to find a way to burn the fuel more completely. Some possibilities are increase the compression(pistons, forced induction) or get hotter spark plugs.
I'm just trying to let people know what is best for their cars. If you don't want to believe some of this, do some research yourself or choose to live in ignorance.
Old Jul 8, 2002
SkyGorGor's Avatar
Here's another link:
http://www.caranddriver.com/xp/Caranddriver/features/2001/november/200111_feature_gasoline.xml?&keywords=fuel&page=1
Old Jul 8, 2002
FlippedOut's Avatar
FlippedOut is an unknown quantity at this point
i use tap water and sugar...
its cheap and inexpensive...
90% water
5% sugar
5% lemonade for the fresh air smell...
Old Jul 8, 2002
L23Tan's Avatar
Thanks for all the replies everyone. I guess it all just comes down to a personal preference to which gas ppl use, and how conveniently it's located to where they live. Altho, after reading what SkyGorGor posted, I have to agree that there's some point (in my opinion) to what he was saying about using a higher octane gas in a lower compression engine, and how it won't completely burn... etc etc. I think I'm just gonna have to try everything and see which I like...
Old Jul 8, 2002
nitehawk's Avatar
I usually use Shell bronze but about every 3 fill ups I will put in Gold just to to keep the lines clean. I do think that what that other guy posted seems pretty realistic. I think that using the highest octane gas in our type of vehicles is a waste, but it couldnt hurt to rotate one in there once a month.
Old Jul 9, 2002
SkyGorGor's Avatar
Actually, if you want to clean your fuel lines and stuff, you should use a fuel system cleaner, and NOT a higher octane gas. It's like, would you put in a bottle of octane booster over a bottle of fuel system cleaner to "clean"? As said in the link I provided, octane is not a rating for performance...it's not going to do any good to have the unburnt fuel to build up inside your engine.
Old Jul 9, 2002
nitehawk's Avatar
Good Point SkyGorGor!!
Old Jul 10, 2002
L23Tan's Avatar
Well, I've tested out Sunoca's Ultra 94 these past 2 days... and I don't know if it's any better than Shell Gold (91 Octane), which is what I was using prior to trying Sunoco. This might sound weird, but in my opinion, it actually feel like there's less of a boost now, then when I was using Shell Gold. Do you think it's because the octane is so high that the fuel is not igniting as effeciently as it should be? I mean, our cars are suppose to use 86 octane or higher, but premium isn't a must. So I think 94 octane is just a tad too high for our engines. I floored it on the highway today and I didn't feel that same "kick" that I used to feel with Shell Gold. Same with accelerating from a dead stop. I'm still in the experimenting stages... so after I drain this tank, which will probably take a lot of driving... I'm gonna try using Sunoco's Plus (89.5 Octane) and Supreme (92 Octane). And if nothing satisfies me... it's back to Shell Gold for me.
Old Jul 10, 2002
SkyGorGor's Avatar
Ok...first of all, read the links that I provided before.
Second, putting in a tank of regular after "draining" a tank of premium is not instantly going to give you regular gas...your system is so diluted it will take roughly 2-3 tanks for the gas to become all regular.
Third, your car's computer can sense what octane gas you are using. It will then automatically advance or retard timing so that the gas will burn efficiently. But as said before, on a stock car or a car with basic bolt-ons, you will not need anything over what is recommended, which is regular low octane gas. Using the higher octane will only leave you with carbon build-up over time.
Lastly, the feeling that you got by using the Ultra94 could either be because the computer hasn't had enough time to re-adjust itself to the optimal timing, or it could be all in your head.
Stick with whatever type of gas you want to use and stick with it.
Old Jul 10, 2002
Naito's Avatar
Naito is an unknown quantity at this point
Order of Preference:
1. Sunoco
2. Sunoco
3. Petro Canada
4. Esso
99999. Shell
Tried all the different gasses before on a '93 Accord I used to have. Shell GOLD gas makes the car feel more lethargic than Sunoco Regular!
Both Sunoco and Petro Canada have ethanol in their gas, which is an octane enhancer, engine feels smoother with it, Esso haven't tried extensively.....but I'd stay away from Shell....I always fill up usually Sunoco Regular, and monthly with Sunoco Ultra 94
Old Jul 10, 2002
L23Tan's Avatar
Quote
[hr]Originally posted by: SkyGorGor
Stick with whatever type of gas you want to use and stick with it.[hr]
Damn... u know a lot about gas, huh? Good stuff... thanks for taking the time to reply. Maybe the computer hasn't had enough time to re-adjust itself just like you said... or maybe it is all in my head. You also said using a higher octane gas will leave carbon build up over time. Okay, now I definitely do not want that. So, since 94 octane is the highest available for the road... I think I'm just gonna stick with Sunoco's Plus (89.5 octane) after I run the whole tank of Ultra 94 I have now... that should be good, right? Question tho... what gas do YOU use???
Old Jul 11, 2002
SkyGorGor's Avatar
No, I don't know a lot about gas.
I use Petro Canada or Esso regular simply because there are a lot of those around where I live, and around the GTA. It's just a convenience thing. No matter what brand it is I always pump regular.
Old Aug 1, 2002
expense's Avatar
expense is an unknown quantity at this point
i use citgo regular 87 most of the time..
