Where can I get something rethreaded in T.O.?
Old Apr 12, 2005
BananaSkin's Avatar
BananaSkin is an unknown quantity at this point
Wassup guys,
Before you read on, just letting you know that yeah, I know I'm an idiot . K, feel free to continue!!
What happened was that when I installed my momo shift ****, i had to screw in these tiny little screws at the base of the ****. Thing is they were suppose to put pressure on a rubber thing inside the ****, which in turn would put pressure on the shift rod and prevent the **** from moving around. But what happened was the rubber peice was out of place when i screwed the little screws in and now the shift rod's threads are smushed in some areas. Therefore I can't screw my new **** (an RSX one) all the way down!
Any places you guys know that can fix the threads? Or if it is even possible?
Thanks for reading and for all replies!
Old Apr 12, 2005
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
you can get a too called a thread file prolly at crappy tire. It should clean up the threads enough.
Old Apr 12, 2005
Blkcivic's Avatar
humm the threading die might work but if the shifter is harden then it might be a problem but i doubt the shifter is hard. Lapping compound or buy a nut with the same dia and ptich and just softly rethread the part that is smushed. The thread is metric i think.
Old Apr 13, 2005
SlimmKidd's Avatar
SlimmKidd is an unknown quantity at this point
See us Tool and Die apprentices know a few things!@!!!
amrhamed
Sep 1, 2015 06:27 PM
HRcivic
Sep 4, 2009 01:30 PM
skiboard
Jul 21, 2005 12:56 AM
bboytius
16
Oct 26, 2004 11:49 AM
