Can someone explain......!!!
Old Jul 9, 2004
vicLX's Avatar
<--That really is ME
Exclamation Can someone explain......!!!
I got my new stuff put in today and the passenger pads that were takewn out was 90% gone....
but the Driver side pads were only 40 % gone????
Old Jul 9, 2004
zen_master's Avatar
do you carry overweight passenger?
Old Jul 9, 2004
vicLX's Avatar
nah... if anythig the weight is on my side cause Im a good 200lbs
Old Jul 9, 2004
Booohahaha's Avatar
BAD MON
maybe ur turning too hard at the track
Old Jul 9, 2004
vicLX's Avatar
naw.. i just remembered ... i probably had a air bubble on my line causing no pressure for the driver side brakes...
Old Jul 9, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
i like ur advatar
Old Jul 9, 2004
smokedcivic's Avatar
"SLIPSTREAM R"
smokedcivic has a little shameless behaviour in the past
no its probably the slider pin or even the caliper...
told you to bring it by.....
Old Jul 10, 2004
Touge_Motors's Avatar
Touge_Motors is an unknown quantity at this point
Slider pin... thats all...
Old Jul 10, 2004
zen_master's Avatar
slider pin? what's that?
Old Jul 10, 2004
vicLX's Avatar
yeah whats that????
Old Jul 12, 2004
"SLIPSTREAM R"
a slider pin is what lets the caliper slide in toward the pad and outwards. If that pin does not have enough grease it will seize up.
Now everyone should know what a caliper is and if you don't don't be discouraged... the caliper is the main part of the brake system, its what pushes the pad into the rotor which then you will slow down or stop the vehichle... if that caliper were to seize up all i have to say is wow your in trouble. Well not really but you would either have to overhaul the caliper piston or just a striaght replace. So you better make sure you know who is working on your brakes.. It could be real time consuming and very costly.
It could also be that they didn't clean the surface of the rotor b4 they put the pads on, so that means that when you step on your brakes you are really rubbing off the preserved oil or grease that is on the rotor..
or that they could of also accidently left some grease on the inside of the pad(where the pad sits on the rotor) and that could cause a sqeeking noise... I know this was not the question but i thought i would share some input that i haev about brakes.. hope this helps some peeps out...
