need help deciding on springs...
I don't really think your spring choice has too much to do with cornering limits. Springs absorb bumps and irregularities in the road. But, a lowering spring will lower your car's centre of gravity making it more stable through corners.
Tire adhesion (grip) and roll-control contribute more to cornering limits then the springs do. If you want to corner fast, invest in some sticky tires and upgrade your sway bars to bigger RSX ones.
Feel free to correct me if I'm wrong.
what im getting from this thread is the neuspeed sports is a better spring then the eibach prokit? is that right?
eibach pro = 2" drop front and back...
neuspeed sports = 1.5 front, 1.75 back
whats the price difference?
will i notice the .25 differential between the front and the back?
does the neuspeed drop look as good as the eibach drop? being that its not quite as low?
^^noob questions i know lol...im totally new to lowering
Originally Posted by JDMGSR4DR
I am interested in the prokit but I want as close as I can get to stock. You guys who have them think it is a good choice?
I"m also looking for a new set of springs. I want the front to be lower then the back, by saying this I want it lower from the ground. It seems really wierd that like neuspeeds the rear is a 1.75 inch drop but it seems straight with the front... neways. Can someone help me with this issue...
Lets run this again.. front is Lower from the ground then the back
Biff, I saw your ride, and I think the drop is too much to be Pro-Kit. Are you sure you are not using Sportline? Are you using stock shocks?
I'm in the market too looking for suspensions and Eibach + Tokico's is in the top of my list.
Looks great tho!!
Looks great tho!!
Its the Pro-Kit, its kinda deceiving i think because the tires that came with the rims have more rubber on them than i wanted.. i decided to try them to see if they would fit.. and they did!!
The only other mods on the suspension are the upper front strut bar and 4-wheel camber kit. The shocks are stock, this is the next thing on the list.. either Tokicos or Konis.. not sure yet. If i put the sportlines on my car these wheels would more than likely not fit.
you'd be fine.. its only another 1/2 " from the pro kit.. and i have all kinds of room on mine even with the amount of rubber on my ride.. be safe and put coil overs on for when you change to winter tires if you do (stock wheels for those"
solarpunk70
Apr 12, 2016 11:43 AM
Munzy
21
Oct 7, 2015 07:48 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
TheRiddicles
Sep 21, 2015 03:34 PM
