Rear Signal Bulbs
Old Jun 16, 2004
Macko's Avatar
Macko is an unknown quantity at this point
Rear Signal Bulbs
Does anyone here know wher ei can get a higher output 3156 Signal bulb for the rear lights? cause i did something and the OEM ones is not bright enough..
Would the 3157 "dual filament" work?
Old Jun 16, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I thought they were 7440's?
Anyhoo, if you're looking for something brighter, perhaps if you grab some crazy hyperwhites from any ricey shop they will shine through better. But if they're tinted blue, maybe not.
Also getting a dual filament won't do anything about increasing brightness, all it does is give you a way to power the bulb from two sources.
Old Jun 16, 2004
They are single filament 7440. I'm assuming you want the brighter bulbs for the stock tails that are red. Well Raybrig makes a hyper clear bulb that's 2x brighter than stock. It's not a coated bulb, but still there is a big difference. I have the 168 mini bulbs in my sidemarkers and dome lights, and the 7440 in the reverse lights. They look just like a regular clear bulb.
Check out racinglab.com
http://store.racinglab.com/rayrevligbul.html
Old Jun 17, 2004
Macko's Avatar
no they're 3156 single filament.. i dunno if Krypton gas is brighter anyone know.. cause i found some krypton filled bulbs (not the ricey kind) they were clear...but i dunno cause it didn't say anythign about brightness it was made by phillips
Old Jun 18, 2004
Try to see if the raybrigs come in that size. They're the best if you can find them. I thought 7440 because I have a sedan.
JohnnyBxo
Nov 12, 2015 03:04 PM
Nalmonte
Jul 22, 2015 09:08 AM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
OptimisticWay
Jul 10, 2015 04:31 PM
SpecialRequest
Jul 7, 2015 07:52 PM
