replacing timing belt
Old Jun 2, 2004
Macfay's Avatar
Macfay is an unknown quantity at this point
anyone here replace the timing belt yet?
my car reaches 92000km already...I'm kind of worry that the belt will break apart very soon...
any replacement belt out there? racing type maybe? I heard there are some timing belt which last very long...any idea?
Old Jun 2, 2004
Well, Honda doesn't say it needs it until 120,000 miles (90,000miles by the old standard). So you still have some time. It's a big job and costs alot.
Old Jun 2, 2004
Macfay's Avatar
thanks, i'm just kind of worry since i always race...
Old Jun 2, 2004
1llmatic's Avatar
1llmatic will become famous soon enough
i believe you're suppose to change your timing belt at 96 000km.
its a major tune up thats dollars.
since you race all the time that means you are driving your car under severe conditions.
Old Jun 2, 2004
Macfay's Avatar
oh...so is there any racing type belt out in the market?
Old Jun 2, 2004
bluewinter's Avatar
bluewinter is an unknown quantity at this point
I've been hunting for one for a while but have had no luck finding anything. I have 116K on mine and can definately feel some slippage.
I went to Formula Honda in Scarborough and found out that the timing belt and ECU have to be changed both at 120K. The cost for the belt is $299 and the ECU is $199 not including install!!!
Old Jun 2, 2004
Macfay's Avatar
why need to change ECU?
Old Jun 2, 2004
1llmatic's Avatar
ECU?...are you sure?
Old Jun 2, 2004
Macfay's Avatar
Originally Posted by bluewinter
... The cost for the belt is $299 and the ECU is $199 not including install!!!
ECU cost $199? that's cheap...if so, I may get one and send it to jetchip...just my thought..haha..
Old Jun 2, 2004
You don't need a new ecu ever unless it breaks. Timing belt is good to do at 90k miles, just in case. If it breaks, you're in alot more repair money.
Old Jun 3, 2004
iamfob's Avatar
iamfob is an unknown quantity at this point
new ecu? that's new to me and unheard of
just change the belt, water pump and u will be fine
Old Jun 3, 2004
iamfob's Avatar
any also i never heard of any racing timing belt for our car
just stick with oem timing belt till a company makes "racing timing belt" for our car
Old Jun 3, 2004
Macfay's Avatar
thanks a lot guys!
Old Jun 3, 2004
O1Coupe's Avatar
O1Coupe is an unknown quantity at this point
Actually I called Honda and they told me to change it @ 160,000km
It's not like the 1.6L piece of *****
Old Jun 3, 2004
Karumba's Avatar
Boredom causes changes ;)
Wierd .. normal replacement for the timing is 120k kms I believe, but we are not the same person so you can do whatever you like. Hell I know people that do not change their oil (and filter) regularly, most often going 10k kms between changes.
Though I don't know why the ECU would be involved/recommended to be replaced, if anything the water-pump would be wise to replace as you replace the timing belt.
Old Jun 3, 2004
iamfob's Avatar
WERD
Old Jun 3, 2004
civic_khaos's Avatar
civic_khaos is an unknown quantity at this point
when you get the timing belt replaced, the water pump is replaced along with it. i had mine changed at 105,000 miles. i was lucky and found a good deal where is only cost $340 US. All other dealers in my area were quoting around $500.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
sharp66
31
Jun 12, 2022 08:45 AM
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
