Difficulty of installing MOMO steering wheel?!?!?!
Old May 20, 2004
kizak's Avatar
kizak is an unknown quantity at this point
For those who have experience in removing and installing an aftermarket steering wheel, I would just like to know how difficult the process is and the approximate time required for install.
Should I do it myself or bring it some where to have it done? Last thing I want is an airbag in my face and no steering wheel.
Any help is appreciated, thanks.
Old May 20, 2004
SiRB16's Avatar
SiRB16 is an unknown quantity at this point
you can do it yourself....the airbag will not deploy...only the sensor can trigger it to.....remember to disconnect the battery first.....
the only difficulty you will be running into is how to make the horn button work....
contact vic_lx or smokedcivic for assistance.....
Old May 20, 2004
vicLX's Avatar
<--That really is ME
Um yeah... follow the DIY and take off the OE hub... the HORN wire is under the column... and you'll have to modify it so i can touch the copper part of the MOMO hub... BUT remember the wheel has to spin.. so you cant soder or clip it on
I got it done at a shop and the guy explained it to me...
the only problem you'll end up running into is the horn to werk.. so you'r better off getting a shop to do it..
and if not.. good luck...
and ALSO use search .. I posted this exact same topic last week
Old May 22, 2004
iamfob's Avatar
iamfob is an unknown quantity at this point
vicLX: after you got the wheel installed, did the SRS light come on?
Old May 22, 2004
vicLX's Avatar
OH yeah......ad reseting wont fix it...
so take out the bulb... or cover it with black electrical tape... in my case... the wheel is slightly smaller and block the light so I never see it
Old May 23, 2004
iamfob's Avatar
icic, i guess one day when i put the stock civic wheel back in the car, i will bring it in to the dealer and tell them clear it for me under extended warranty (i still dont get why my dad bought extended warranty on the 7th gen)
Old May 25, 2004
kizak's Avatar
thanks guys, I guess I'll give it a shot first if not, I'll just take it to a shop.
honda200192
Suspension
Oct 27, 2019 12:23 PM
Supramk3
Jun 11, 2015 11:13 AM
anddrrey
May 11, 2015 02:30 PM
JDQuikCivic
Nov 22, 2001 01:26 PM
1028CiViC
Bolt-on Engine Performance
Nov 18, 2001 05:02 PM
