strut bar install
Old Mar 21, 2004
sictoy's Avatar
sictoy is an unknown quantity at this point
Question strut bar install
I just got a upper front and rear strut bar, my question is that can I use a socket wrench to bolt it on or do I have to use a torque wrench and tourque it to a specific ft/lb?
Old Mar 21, 2004
Sunapollo's Avatar
Sunapollo is an unknown quantity at this point
it's better to torque it to the spec but it's okay if you just screw it on ...
Old Mar 21, 2004
I just used a socket wrench. Make sure you tighten it good.
Old Mar 21, 2004
Booohahaha's Avatar
BAD MON
u should check the owners manual. i think its in there, the last time i checked when i got my strut bars installed
Old Mar 21, 2004
sictoy's Avatar
nvm i got it....HOW THE HELL DO YOU TAKE THESE BOLT OFF!!...mine are on reallly tight!
Old Mar 21, 2004
phuviano's Avatar
Slowest 7thgen in the GTA
lol... just keep trying. They are on pretty tight, but just give a little more and it'll go.
Old Mar 21, 2004
smokedcivic's Avatar
"SLIPSTREAM R"
smokedcivic has a little shameless behaviour in the past
i torqued mine on at about 15-20 ft/lb,
so not to tight, if you do it to tight you can strip the bolt and ruin the stud mounts.
Old Mar 21, 2004
Liro's Avatar
Back from the dead
doesnt the manual say what to torque it to?
Old Mar 21, 2004
Neuspeed says 33ft/lbs. So it's pretty tight. You don't want them to be loose. And to get them off, try using a hammer and socket wrench to get it loose. Takes some muscle.
Old Mar 21, 2004
MSoft's Avatar
MSoft is an unknown quantity at this point
If you don't torque it on properly, it will eventually come loose... Last thing you want is a strut bar in your engine compartment flopping around... Imagine the damage...
Old Mar 22, 2004
Liro's Avatar
Back from the dead
yeah, definately...that and you dont want your struts loose either
bluecoupe
Nov 28, 2001 08:21 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
CapYoda
Nov 20, 2001 10:36 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
andylao
Nov 4, 2001 01:19 PM
