Hyper Ground and Hyper Voltage Systems installed!
Well dudes! I've just installed them both! I was in my garage in sub-zero temperatures this morning installing them... My fingers were icecubes by the time I finished! Anyhow, I finished! I took the car out for a small drive.. but not a very long one.
When the weather warms up a bit (as it should on the weekend), I plan to reposition the HGS and HVS a bit. Since this was my first time ever installing one of these things, I wasn't sure the wires were gonna be as stiff as I thought
and the HVS has slightly longer wires than I thought. To sum up all my rambling I just said.. I pretty much have to re-orgainize since it looks a TAD messy right now inside there.
Moving along... what I noticed! In the short duration I've had the system in... and drove it around.. I noticed that when I started the car... it started much easier! This could have been because I started the engine recently.. the real test is tomorrow morning! When accelerating, I've also noticed that the hestitation that was previously there at some RPMs is now gone. The acceleration is much smoother than it was in the past. Also at lower RPMs.. under 1500... and above 1000... that RPM range where your engine rattles and makes this funny sound... there's more power around that area dragging it out of that RPM area. Furthermore, when you downshift and let yourself engine brake, there's less jerking as the engine braking is smoother. Also in first gear where if you were to coast at idle.. then go to 1500 then coast again to engine brake (your vehicle jerks a bit here and there as it approaches idle), there is a lot less jerking.
Welp... more to report in coming days.
For sure! Tomorrow afternoon as soon as there's more light and I move a wire or 2 around a bit to make it a bit cleaner
Update: Just went to start my car that has been sitting in the cold for a while. You know when you usually start your car after like 4 hours when it's been sitting as a block of ice outside... your engine goes.. crank crank crank VROOOOOOOM and goes up to like 2000 rpm to start? Well... I just started it... and it cranked twice and started and it started @ like 1200 rpm and moved up to 1400 rpm where it usually sits when warming up! THat's a DEFINATE improvement!
i should really install mine then.... been sitting in my room for a long long while now =/
but as for the hyper voltage... dont have the money for that.
what is that meant for again>? ... to even out the electric output...? or something like that...... o_O
Welp...! As you know dudes... it was freezing last night.. -5 celisus.. and tonnes of snow! Anyways.. I go out this morning to start my car...
CRANK CRANK vroom! Starts up no problem! Usually you put your key in and it goes CRANK CRANK CRANK CRANK CRANK CRANK CRANK then goes VROOMMMM!
My car cranked twice and then started with no problem! Usually my engine after it cranks goes VROOM to 2000 rpm before dropping down to 1400 to warm up...
Anyways... this morning it goes vroom instead of VROOM ... starts up at like 1200 and then moves to 1400.
I've yet to see the fuel mileage this thing gives me since I've only had it for 1 day.
I've just got back from my finance exam.. now I gotta study for my next exam! 8 AM Wed!
Originally posted by vicLX
ahh dont worry about htis thug... he just mad cause he aint black
neways, don't buy from this seller.. he is stupid... just go ahead see what's gonna happen if u have business with this vicLX.. not just he is a FOB who can't speak english right... he is totally ****ed up when it comes to business. I ain't gonna say why... go ahead if you wanna experience it.. go ahead
vicLX LEARN UR ENGLISH MAN! AFTER YOU LEARN YOUR ENGLISH.. THEN GO AHEAD HATE MAH PIC! AND OTHERS PIC! OK!? DON'T HATE WHEN YOU CAN'T EVEN SPEAK IN ENGLISH RIGHT...
"CAN SOMEONE SAW WANKSTUH?"
"DID I DID IT?"
"HAVE YOU SAW IT?"
"TRYING BE ALL NIGGUH?"
OH MAN YOU'RE A FOB!!! LEARN YOUR ENGLISH GRAMMMAR!!!
PEACEOUT YOU GUYS.. AND SHUT THE *** UP! vicLX.. be ashame of your self...
Ok...
Both of you guys... STOP YOUR BITCHING PLEASE!
And pnoiracer.. from what I've seen above... your grammer isn't too much better....... so lets just drop it. Thanks.
Originally posted by pnoiracer
whatta reason.. no u just mad coz u hatin mah pic and what u said was.. "can somebody SAW wanksta?" and I laughed so hard.. coz I don't know how to get ur english right everytime u criticize mah.. and Im teasing you a F O B!!! everytime u talk to me ur grammar is terrible... LEARN ur english first man b4 hating (just an advice)
"DID I DID IT?"
"HAVE YOU SAW IT?"
"DID I DID IT?"
"HAVE YOU SAW IT?"
....man i hate kali flips who think they are so hardcore.......y do u have to start **** on this forum....ur the idiot for doing that......y would we listen to u now...that ur causing a flame war.........*** ....do all kali flips act this way.....thats what i notice....u guys get offended so easily
"DID I DID IT?"
"HAVE YOU SAW IT?"
"DID I DID IT?"
"HAVE YOU SAW IT?"
You’re talking about bad grammar? Let’s start with you.
“whatta reason” --> I can’t figure out what the f u c k you’re trying to say in your opening sentence.
No, you’re just mad because you hate my picture. What you said was, “can somebody SAW wanksta?” At first, I laughed so hard because I don’t know how you can criticize my English when YOU can’t even speak it properly. You’re definitely a FOB!!! Every time you talk to me, your grammar is horrible to read. LEARN your English first before you start your hatred on other people (just my advice).
So, DO NOT buy from this seller, Viclx. He is stupid, so buy at your own risk and you will receive your consequences if you do business with this guy. He is not just a FOB who can’t speak English properly; he is totally f u c k e d up when it comes to business. I am not going to give reasons why but go ahead if you want to experience a bad business transaction. GO AHEAD =)
Viclx, LEARN THE ENGLISH MAN. AFTER YOU LEARN YOUR ENGLISH, THEN GO AHEAD AND HATE MY PICTURE. YOU CAN EVEN HATE OTHER PICTURES, OKAY? ***not ‘ok’ – it’s OKAY*** DON’T HATE WHEN YOU CAN’T EVEN SPEAK ENGLIGH PROPERLY.
"DID I DID IT?"
"HAVE YOU SAW IT?"
OH MAN, YOU’RE A FOB. LEARN YOUR ENGILSH GRAMMAR.
PEACEOUT YOU GUYS, AND SHUT THE F U C K UP. Viclx, be ashamed of yourself.
You do not need acclamation points when you’re using CAP LOCKS. You’re already shouting, you can’t shout any louder when you’re typing! You’re the true F U C K I N G DUMB A S S. If you’re going to criticize people for their grammar, you should start with yourself first. People like you deserve a major a s s beating. Acting all big and tough behind a damn computer screen. Pnoiracer, hahahhahahahaa, you’re name should be “pnoi the wussy loser”
HAHA.. have u guys heard the word "typo"... well that's what happened to mine.. I knew it and I just didn't bother to correct them (imma lazy *** mothafuka)... neways, atleast not as bad as vicLX.. mine is just the basic ones.. and what the hell... i don't give a ****....
I know mah english dawg.. vicLX.. need to learn big time hahahah!
atleast I don't say.. "can someone saw"
whoever said.. kaliflips think they're hardcore.. we hardcore if u act like one.. *****... we stay real...
it's not that I'm getting offended.. it was because we just need to mind our own business here k? I uploaded the pic for some purposes.. not to show off to that gay guy vicLX who was all getting butt hurt... and not to brag! and that vicLX was somehow affected.. I don't know why.. mind your own biz dud.. **** we need to grow up here man... and it was just coz of a pic... vicLX I don't get you ***.. why don't u just mind ur own biz? if u have something to say about mah pic... just keep it to urself! I know I need to grow up here but come on now vicLX u need to grow up too! how old are u? 22? 23? come on now.. stop hating b1tch..
aznsaint. mind ur own biz.. I know I'm in ur own forum.. but then u stupid.. we don't have to be expert in english here! I cAn Do wAtEvEr I wAnT to my letters and spelling and the way to say it! I ain't like vicLX "can someone saw" now that's different! hahahah... peaceout!
aw wait.. I just read ur stupid reply aznsaint... well *** YOU!!!!! AND I SAID **** YOU!!!!!!!!! CUMSUCKER!!!! why don't u just be an english teacher u fukin a55hole!
can somebody JUST CLOSE THIS FORUM!!!!!!
OK I ALREADY SAID WHAT I WANTED TO SAY... WE NEED TO GROW UP HERE! AND MIND OUR OWN BUSINESS!!!
IF IT'S NOT COZ OF THIS VICLX... THERE'S NO ARGUMENT NOR FIGHT.. MAN WE SHOULD BE FUKING UNITED HERE ALL DRIVERS OF 7THGEN CIVIC... AND VICLX.. SERIOUSLY, U NEED TO CHANGE UR ATTITUDE.. STOP HATING UNLESS U REALLY KNOW THE PERSON.. COZ IF U HATE B4 KNOWING THEM.. U ONLY GONNA SEE THEIR BAD SIDE.. COZ U STARTED TALKIN ****... EVENTUALLY THEY WOULD TOO.. LIKE AZNSAINT.. I STARTED TALKIN **** AND EVENTUALLY HE DID (WHICH WAS STUPID)..NOW GUESS WHAT? ANOTHER FIGHT.. HAH! BUT I DON'T REALLY CARE..... LATE U GUYS.. PEACEOUT!
Yes, it's an Acura EL
vicLX - NOT a FOB, but what would be wrong with that?
Many peeps on this thread - Flips, so why are we fighting?
This thread - totally jacked, someone please lock/delete
Monkeys and robots - just plain hilarious
First off, I am an English teacher, you f u c k I n g illiterate English moron. I’ve thought I’ve seen stupidity already, but now I’ve seen it all. If you’re going to stop, like you said you would, then stop! Don’t say you’re going to stop, then talk s h I t again and then say you’re going to stop again. You incompetent piece of ****.
Secondly, yes, you can type however you want in your letters and spell the way you want, that’s cause you’re big and bad pnoi the wussy loser, right? “DAWG.”
“We need to grow up here.”
You should start with yourself, people in this forum are just backing up Viclx. So if you’re going to start ****, start it somewhere else. If you didn’t realize, it was YOU who started **** on THIS THREAD. So watch what you say before you start offending people on this forum. If you have problems with Viclx, then keep it to yourself and solve in a different way. But not on this forum, or people will trash you. As we don’t know who the f u c k YOU ARE. YOU GOT ME? DAWG.
And it’s good, that you’re supposedly trying to make peace, so let’s keep it that way. Or else, just shut the f u c k up because all you’re doing is just speaking a f u c k I n g jiberish language.
