how to disable the Daytime running lights
Old Oct 20, 2003
MattC1's Avatar
MattC1 is an unknown quantity at this point
I have HID's installed but my frigging DRL is lit up, how do I disable it... fuse? thanks for the help
Old Oct 20, 2003
TeLLy's Avatar
Yes, it's an Acura EL
I think there are a couple of fuses for DRL. Check ur manual for those.
Also I just found this:
1.) Be sure all the power in your car is off (lights turned off, engine off, etc.)
2.) Have a pair of needle nose pliers and flash light handy
3.) Remove the panel under the steering wheel by turning the 2 *****
4.) Look at your fuse panel and remove fuse 12 and 3 (7.5 and 10 amp fuse), #3 fuse is the third from the left on the bottom row....12 is the 2nd from the left on the second row from the bottom
5.) Place the panel back and place the fuses somewhere you can find them if you need them in the future
6.) Turn on the car and your daytime running lights are now disabled
*taken from this link originally by ASIANPRIDE:
http://www.7thgencivic.com/forums/sh...aytime+running
Old Oct 20, 2003
MattC1's Avatar
Thanks TELLY for that, I will give it a try
Old Oct 20, 2003
TeLLy's Avatar
I wanna wire my parklights to come on instead of headlights as the DRL's...
Old Oct 20, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
i've been thinking about using the parking lights instead of the drl.... but i haven't been able to find the time to search through the wiring..... let me know if you find a way telly....
Old Oct 20, 2003
TeLLy's Avatar
I think I've got somethin....sounds real risky but I'll give it a try.
Old Oct 21, 2003
EL-Sport's Avatar
EL-Sport is an unknown quantity at this point
Yes, all you have to do is simply remove once fuse and voila no DRLs. I did this awhile ago on my EL, but I only removed one fuse, not two.
Old Oct 21, 2003
MattC1's Avatar
which fuse did you remove EL-SPORT?
Old Oct 21, 2003
Mystix's Avatar
Mystix is an unknown quantity at this point
lol wow how many clubel-ers on here?
Old Oct 21, 2003
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
i only removed one fuse too...forgot which one it was..
Old Oct 21, 2003
Dr5D's Avatar
dosent the fuse controll more than just the DRL??? kind like if you take out the fuse for the stero other stuff also stops working...
Old Oct 22, 2003
EL-Sport's Avatar
No, the one fuse I took out only had DRL listed on it. If I remember, I'll check my car tonight and let you guys know exactly which one it was.
CarStuff
Dec 6, 2020 12:52 PM
werdnahall
May 17, 2015 11:37 AM
eorlando1
May 17, 2015 11:16 AM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
cazminn
Nov 9, 2001 11:18 AM
