GB on Faze Gauges
Old Sep 23, 2003
  #31
TeLLy's Avatar
Yes, it's an Acura EL
No problem - this GB should go for a LITTLE bit longer, we're still just under the quota. Prolly another week or two at most tho.
Old Sep 23, 2003
  #32
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
i would have thought way more ppl would have jumped on this gb..... the prices for these guages with these features are relaly good..... i'm so eager to get these puppies in my car... heehee
Old Sep 23, 2003
  #33
TeLLy's Avatar
Me too!!! Yeah he said the way things are goin mid-Oct will be the cutoff.
Old Sep 23, 2003
  #34
AznSaint's Avatar
AznSaint is an unknown quantity at this point
im really interested, but not sure what kind of gauges i want.
what are usually the common ones>?
Old Sep 23, 2003
  #35
TeLLy's Avatar
Air/Fuel, Volts, Oil Pressure are the ones i see the most.
Old Sep 23, 2003
  #36
AznSaint's Avatar
thx.
well, im gonna most likely be getting a gauge bazel... which only holds two.
if iw ere to put them on the side.. like i see other cars that has it done.. do they buy a new side panel? or do they just drill holes in 'em>???
'cause my panels are all vinyled.. so im just curious
thx.
let me know whenever the final deadline is.
im in this group buy for sure. 100% wont back out
Old Oct 15, 2003
  #37
SedanBoy's Avatar
hey telly, any word on how or when this gb is going to happen?
Old Oct 15, 2003
  #38
AznSaint's Avatar
oh ya.. count me in 100%
Old Oct 15, 2003
  #39
TeLLy's Avatar
Oh yeah, i just talked to him today, he's gonna close off the deal within a couple weeks.
Aznsaint have u emailed him?
Old Oct 16, 2003
  #40
SedanBoy's Avatar
eeeeeeeeeexcellent.....
Old Oct 16, 2003
  #41
TeLLy's Avatar
If you're anything like me, you're tapping your fingers together a la C. Montgomery Burns as we speak....yes....
Old Oct 16, 2003
  #42
TeLLy's Avatar
OK just talked to Dave again. He is taking orders till the 26th of Oct (Sunday) and he expects money in by Halloween - Oct 31st.
Old Oct 16, 2003
  #43
SedanBoy's Avatar
yesyes... the finger tappin has been for awhile now....... heehee
Old Oct 16, 2003
  #44
SedanBoy's Avatar
sounds good to me... so we can probably aim for a install meet around mid november?... haahahah... yes, i'm excited and starting to plan things way into the future... hahahahaha........
Old Oct 16, 2003
  #45
TeLLy's Avatar
Huzzah!!! Now time to learn how to install these...
Old Oct 16, 2003
  #46
SedanBoy's Avatar
hahaha..... they shouldn't be that painful to put in...... but then again, there are the unexpected..... heehee......
i'm just trying to decide on how i'm gonna mount them.... i'm probably gonna put them on the pillar for now and then think up something else for them.....
Old Oct 16, 2003
  #47
AznSaint's Avatar
are you guys referring the pillar pods to gauge pods????
Old Oct 16, 2003
  #48
SedanBoy's Avatar
i'm going with the pillar pods.... i think telly is going with a gauge pod....
Old Oct 16, 2003
  #49
TeLLy's Avatar
I'm goin pillar.
Old Oct 16, 2003
  #50
AznSaint's Avatar
i still dont know what a pillar pod is. o_O anybody have a link ot a pic? haha..
thanks.
Old Oct 16, 2003
  #51
TeLLy's Avatar
Old Oct 17, 2003
  #52
AznSaint's Avatar
thx.
so the pillar pod is the whole front upper panal>?
... is that a corsica? o_O
Old Oct 17, 2003
  #53
SedanBoy's Avatar
Originally posted by TeLLy
I'm goin pillar.
oops... sorry about that..... for some strange reason i thought you were going with the gauge pod.....
Old Oct 17, 2003
  #54
TeLLy's Avatar
Silly monkey.
Old Oct 21, 2003
  #55
AznSaint's Avatar
can someone please explain what each aftermarket gauges exactly does>?
oil presure.....
water/oil tempature.....
volt....
air fuel ratio....
i sort of know what the volt one does. i think...
the oil presure... does it measure how good the oil is in your car? of course im not talking about the gasoline..... haha o_O
the water/oil temperature.... is that the same one that honda provides us with on our oem dash? .. where our speedometer is.?
air fuel ratio is the one i want to know most about... 'cause i know nothing about this one. i read the lil' info that they provided on the site.. but did lil' help to me.
thanks.
oh ya.. one more thing? aren't most gauges 2.1/16" ?? 'cause the faze gauges are 2"
just wondering, thanks again
Old Oct 21, 2003
  #56
AznSaint's Avatar
and what's the major/minor differences between the mechanical/electrical gauges..? 'cause they are all 2" dial face.
the ppl that are in the group buy... sedanboy.. or telly.
which ones are you purchasing? and if they're the oil pressure or the water/oil temperature.... are you getting the mechanical or electrical onee...? and why>?
thanks again.
Old Oct 21, 2003
  #57
AznSaint's Avatar
Old Oct 21, 2003
  #58
SedanBoy's Avatar
i'm picking up the a/f and volt, along with the pillar pods.
as for the diff between electrical and mechanical, if i'm not wrong, the mechanical gauges, oil for example, you need to tap and run and oil line to the gauge itself, whereas the electrical gauges usually have a sensor that you tap into the oil pan or whereever.
maybe telly can elaborate or correct me on some of this.
Old Oct 21, 2003
  #59
TeLLy's Avatar
Sedanboy is right - mechanical gauges by definition tap into the line that they are monitoring. The water/oil temp gauge is a perfect example, as there are both electronic and mechanical versions.
The mechanical gauge is tapped right into the line that the oil/water actually goes through (or the oil pan, I read up on installin mech gauges but that was a while ago....I'm stupid) - you will have to cut hose/pipe/metal to fit the sensor on then run it into the car and then into the gauge.
The electrical version taps into the pre-existing wire (leading to ECU I surmise, someone please correct me if I'm wrong here) that leads from the thermostat.
I personally prefer the possibility of futzin up a wire as opposed to an oil/water line, so I would go electrical myself. But my volt and a/f gauges are both electrical only anyhoo.
Old Oct 21, 2003
  #60
AznSaint's Avatar
thx.
..so what does the air fuel ratio gauge does>? ...... if it's not too much trouble
