has anyone ever . . .
Old Aug 12, 2003
maxEmus's Avatar
a.k.a incamus
maxEmus is an unknown quantity at this point
installed their own rsx rear sway bar and could give me a few pointers on how to install it myself.
or if possible can help me install mine?
much appreciated.
neil
Old Aug 12, 2003
maxEmus's Avatar
a.k.a incamus
oh yeah i live in makrham and am willing to drive to locations that are in proximity.
Old Aug 12, 2003
GreenNVicious's Avatar
Newbie
You're gonna need some tools, that's about all i know.
Old Aug 12, 2003
maxEmus's Avatar
a.k.a incamus
what else do i need. i bought the bar and the bushings were there, anything else it that shoulda came with it?
and is it a hard DIY?
Old Aug 12, 2003
TeLLy's Avatar
Yes, it's an Acura EL
Looks easy enough...I'm gonna try this myself next week...click here
Old Aug 12, 2003
cosmicjim's Avatar
cosmicjim is an unknown quantity at this point
very easy install.
1. Jack the car up
2. unbolt then rebolt the new sway bar in
3. only hard part is the endlinks ... you need a vice-grab the bolt from rotating then you can unscrew the bolt off.
Old Aug 12, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
it's really simple...... the hardest part is breaking free the nuts and bolts cuz of the rust....
1. jack up car and put on jack stands
2. loosen the endlinks from the sway bar
3. loosen the braket bolts
(now all the tension is released)
4. take out all bolts and take sway bar off
5. take careful note of which side is which, they are different and this is crucial
6. put new sway bar in and reverse the procedure.
note: once on the ground, nothing should be touching, if the sway bar is touching the lower control arm, you've put it on backwards!
good luck, should take you about 30-45 mins with normal hand tools.
Old Aug 12, 2003
vicLX's Avatar
<--That really is ME
Talk to DriftR on the next meet... hes coming and he did it himself!
Old Aug 12, 2003
maxEmus's Avatar
a.k.a incamus
thanks for the help, i still may need someone to help me out on this if anyone can.
thanks again
Old Aug 12, 2003
TeLLy's Avatar
Hey MaxEmus, hit me up....we can work on it together as I am gonna put mine on next week hopefully.
Old Aug 12, 2003
maxEmus's Avatar
a.k.a incamus
cool ill give you a shout after importfest. and maybe you can help me to paint my headlights
PM me if anything
Old Aug 12, 2003
maxEmus's Avatar
a.k.a incamus
**** it dont look tough at all. but still we'll work on it together just in case.
Old Aug 13, 2003
AznSaint's Avatar
AznSaint is an unknown quantity at this point
i got mine installed when i had my exhaust installed.
with the looks of it... i could of easily done it myself...
it's basically what cosmicjim said... it shouldnt take you more then half hour.
if you need help.. let me know.
i might be doing some more work to my front lights... whitehousing maybe.
i could prolly help you then...
and since your car is new.. there shouldnt be any rust on your bolts. which should make it a lot easier.
my car is about a year's old on the road.... and there was rarely any rust on my bolts.
Old Aug 13, 2003
maxEmus's Avatar
a.k.a incamus
thanks aznsaint, i say ur car the other day, real nice.
ill let you know if i need a hand witht the sway bar. if telly and i are lost, we'll give you a shout.
Old Aug 13, 2003
TeLLy's Avatar
Should be simple enuf. Gonna send cash to my guy this weekend, he will ship overnite so I should have something for mid to late next week.
Old Aug 13, 2003
maxEmus's Avatar
a.k.a incamus
would the rsx sway fit my dc tcs exhaust, i hear yes and i hear no? should/would it be a problem?
Old Aug 14, 2003
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
I won't affect any muffler that you install.... If it fits with the stock sway bar, it will fit with the RSX sway, the design is the same, it's only thicker.
Install is very easy, like I said before if you need help... I'll help you out. The other thing that you need aside from the sway bar and the bushings that it came with is some lithium grease. I can bring this for you guys when you do it at Telly's place. I've had mine for a while and I say it's the best mod for suspension and control.
Let me know when y'all do it.. I'll be there!
