Rebuilding and adjusting a Keihin 3bbl carburetor.
Old Aug 9, 2020
Rebelrider.Mike's Avatar
Rebelrider.Mike is an unknown quantity at this point
I have a 1980 Civic wagon that I absolutely love driving. When it's actually running. A few years ago, my mechanic (the only guy I know in the area who can fix my carburetor) retired. I decided if I want to keep driving my car, I'm going to have to learn all about this weird carburetor and maintain it myself. Here's a picture of me and the "SuperHonda" (as my college friends dubbed it) back when we both looked way better:
For those of you who aren't familiar, for a few years, Honda made this weird engine called a conceptually very complicated crazy engine, or CVCC for short. It has this pre-fire chamber that the spark plug sparks in, instead of doing it directly into the cylinder. Here's a picture:
Compound Vortex Controlled Combustion
The pre-fire chamber needs a separate air/fuel mixture than the cylinder, so someone (I guess it was Keihin the maker) came up with the 3 barrel design. The primary and secondary work just like a 2bbl, and the aux. barrel, number 3, feeds a separate mixture to the pre-fire chamber. This allows the mixture in the cylinder to be extra thin. Along with a crap-load of other stuff that breaks a lot, this made the engine super lean and clean running. At least for its time. I still occasionally get 36 mpg. Better than some modern hybrids.
Anyway, I thought I'd share my learning adventure with you in case there's still someone out there who still loves their CVCC engine and 3bbl carburetor. I have a whole series of videos to share, but I'll start with just the first one, so this post doesn't get ridiculously long.
Just in case someone wants to watch ahead, here is my You Tube channel: MikeGrayM70
Old Aug 12, 2020
Re: Rebuilding and adjusting a Keihin 3bbl carburetor.
Part 2:
Old Aug 15, 2020
Part 3"
Old Aug 18, 2020
Part 4:
Old Aug 23, 2020
Part 5:
Old Aug 26, 2020
Part 6:
Somehow, I mixed up several video links at the beginning of the thread. I think I've managed to get everything in order now.
Old Sep 14, 2020
Part 7:
Old Jan 22, 2025
letank's Avatar
letank is an unknown quantity at this point
I know old post, but great infos about the third barrel... I was wondering what was its purpose.
I have a 3rd with a leaky isolation gasket... the weber swap gasket/base plate does not include that 3rd barrel... thinking of CNC to solve the issue
Cheers to your post
Old Jan 23, 2025
The aux. barrel feeds the pre-fire chamber in the engine. The pre-fire chamber has the spark plug instead of lighting the fuel in the cylinder directly. It's all part of the CVCC engine setup. I've never installed a Weber conversion, but I've heard that there is supposed to be an adapter that sends fuel from the primary barrel to both the cylinder and the pre-fire chamber. But like I said, I've never seen one. I'm one of the few odd folk who prefers to keep the stock carburetor.
Old Jan 23, 2025
letank's Avatar
Finally managed to pull the carb, the rubber insulator is slightly warp, that explains the slight leak while warming up and the loss of idle when warming up
Thinking of resealing with the right stuff and seal all for the gasoline soaked area
TransformedBG
Jun 13, 2005 10:38 PM
Metallica454
Oct 28, 2004 08:56 PM
Mark4124
Aug 11, 2003 02:04 PM
n00dleboy
Jan 29, 2003 10:31 PM
JoeB16
Oct 12, 2002 09:09 AM
