Tranny cooler
Old Feb 10, 2005
Marcus's Avatar
And Pimp I got the Juice
Marcus will become famous soon enoughMarcus will become famous soon enough
Tranny cooler
Has anybody form New York Have, or put in a tranny cooler in there car? If so how do u install one
Old Feb 10, 2005
pon55's Avatar
Be carefull, winter temps can give you problems! I'v installed them on trucks and vans, never on a civic.
Old Feb 11, 2005
Marcus's Avatar
the reason why I ask is becuase I might be moving to FL soon
Old Feb 12, 2005
pon55's Avatar
Why would you want one? They are for towing stuff! Even then you don't need them unless your going slow.
Old Apr 25, 2005
mclean987's Avatar
mclean987 is an unknown quantity at this point
hey pon55 can you tell me how they give trouble in winter i wanna install an tranny oil cooler aswell
Old Apr 25, 2005
Jrfish007's Avatar
If your transmission fluid is to cool, it isn't viscous enough in your transmission, which means your transmission has to work in oil that is to think for it. This causes excessive ware on it.
Old Apr 25, 2005
pon55's Avatar
Originally Posted by Jrfish007
If your transmission fluid is to cool, it isn't viscous enough in your transmission, which means your transmission has to work in oil that is to thick for it. This causes excessive ware on it.
The wind chill on a tranny cooler is hella cold at 60 mph!
Old Apr 26, 2005
dwi's Avatar
dwi
dwi is an unknown quantity at this point
but what if u running boost??? also, how could i make my auto tranny more stronger
Old Apr 26, 2005
Jrfish007's Avatar
Boost on an auto tranny you might want to, depends on how you hard you run your car. If it was me who constanly has my foot on the floor and I don't drive much highway, then maybe. Best thing to do is keep an eye on your tranny fluid, check it at every gas fill up, if it ever becomes yellow or brownish (not the nice pink/red color) you probably over heated your tranny and could use a cooler.
Old Apr 26, 2005
mclean987's Avatar
i need a tranny cooler because im runnin 12lbs boost and i race everyday and drive up hills, ive been through 2 trannys and the synchros keep going bad and its all due to heat the tranny runs real hot and the fluid gets hot and its just sitting there its not like the engine oil where it has a filter and pump and filtration system, doesnt anyone on this site have a tranny cooler
Old Apr 26, 2005
pon55's Avatar
Running a cooler is fine! Only winters are a problem. You should disconect or by-pass it in cold weather.
Old Apr 26, 2005
mclean987's Avatar
imin florida so no problem, i heard i need some kind of pumping device for 5 speed because it isnt like auto where you dont need one, i aint having much luck finding 5 speed tranny coolers
Old Apr 26, 2005
pon55's Avatar
Tranny cooler will NOT work on a manual!
Go to a slightly heavier lube!
Old Apr 26, 2005
mclean987's Avatar
hhaha im using gear oil now anything thinner my 3rd gear synchros grits, is it true that too thick oil cna damage tranny, and do you know which design of oil cooler is better plate or tube and fin ?
Old Apr 26, 2005
mclean987's Avatar
the only reason why it cant work is because it doesnt have a pump like auto tranny but i cna install a pump but so far i cant find the pumps for less than $150
Old Apr 26, 2005
pon55's Avatar
Pumping atf is very diff from gearlube!
Find some "real" roundy-round heads that know like nascar!
The other option is go to Redline or some other oil company and ask help!
Old Apr 26, 2005
mclean987's Avatar
yeh well im plannin on switching back to regular engine oil when i get my tranny rebuilt or a new one or fix synchros
Old Apr 26, 2005
Jrfish007's Avatar
Have you considered having a tranny built for that power/heat?
Old Apr 27, 2005
mclean987's Avatar
thats a good idea ive thought about it but to do it properly that would take over $1000 and i can buy 4 oem ones for that,,hahaha
Old Apr 27, 2005
why are you guys saying this is bad during winter? Do you know how little fluid actually goes to the cooler...it isn't much. I almost think it doesn't help at all. But mine made it through -10 degree winters just fine. You can feel it shifts cold but once the engine warms up everything is fine. Compared to the whole pool of fluid, that small amount that gets cooled doesn't do much.
mistahlorax13
21
Nov 18, 2015 12:47 PM
Whitexj
Sep 30, 2015 02:04 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
speedlever
Sep 24, 2015 07:18 PM
dantheman42
Sep 4, 2015 01:10 PM
