integ engine swap
Old Jun 23, 2003
iLLuMiNaTi's Avatar
iLLuMiNaTi is an unknown quantity at this point
integ engine swap
Hey,
My friend just bought an integ LS with the only purpose in mind to turn it into a sleeper. He wants to do the whole engine swapping thing and turbocharging.. so his question is.. Which engine should he get?? He has 2 engines in mind:
B18C5
or
B20B
The B18C5 is the type-r engine with i think it's around 195hp, The B20B is the engine from the CR-V, which in a normal CR-V produces a lot less hp, but i heard that when tuned correctly can easily produce 200hp with around 150lbs torque (naturally aspirated). Going by the numbers the B20B would be better, but then lots of people say the B18C5 is the perfect engine for an integ.
Any help/suggestions would be nice.
Thx in advance
Old Jun 23, 2003
REDVIC's Avatar
One of few in the 13's
REDVIC is an unknown quantity at this point
B20's will only produce 200hp with the Type R head is swapped on the B20 block... If I was in his situation I would either keep his stock B18 and turbo charge it or make a LS/Vtec motor either with a B16, B18c or B18c5 head...
Old Jun 24, 2003
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
The Type R engine is the perfect motor for an all-motor lightweight hatchback chassis setup, but not many people swap it into a DC2. Your friend could still swap in a B18C5, B20B, B18C1, or whatever he wants. But since he already has the B18B block, he could just put a B16A2 head on it (LS/VTEC) and /or turbo his existing setup for a lot less money.
There is a guy in Houston (Cheezefrog) who is pushing 450+ whp with an LS non-VTEC setup. There is a video of him floating around where he is racing a 10-sec. Viper and keeping up the entire way. Crazy.
Cary (Cheezefrog) is a really cool guy whom I happen to run into on accident everywhere (saw him at the performance shop when I worked at John Eagle, saw him at the 7th gen meet a few months ago, ran into him at the Houston Imports meet about half a year ago, even happened to pull up to him while he was doing tuning runs in his car up and down Westheimer one afternoon LOL).
If your friend is interested in his car's secret formula, you can contact Cary at cheezefrog@aol.com. I'm sure he will be happy to get you in touch with his mechanic/engine-builder friend Jason who just opened his own shop (AutoLogic) in Houston a few months ago.
Old Jun 24, 2003
SuperNegro's Avatar
SuperNegro is an unknown quantity at this point
If he can live with a rough idle he can build a 2.0L non vtec all motor car it would need a good head job and raise in compression but it could run 12's all motor without VTEC most people wouldnt expect it but you have to do your homework.
and he would be better off just resleeving his LS block with 84-85mm sleeves and going from there.
Old Jun 24, 2003
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
B20B....sleeve it...and do a VTEC conversion either...B18C5 is meant for all motor, why go through the hassle of lowering compression etc. Go with B20B or B18A/B, B18C1 even.
Old Jun 24, 2003
ASuave's Avatar
ASuave is an unknown quantity at this point
just keep the LS, sleeve it, and turbo it. forget about VTEC, just get performance cams
Old Jun 25, 2003
iLLuMiNaTi's Avatar
what does sleeving it mean exactly?
Old Jun 25, 2003
VTECTypeR's Avatar
I would just keep the Ls engine as far as sleeving the engine im not to sure what that is.
Old Jun 25, 2003
SuperNegro's Avatar
sleeving means replacing the stock cylinder sleeves with stronger ductile iron ones usually 81-86mm but i have heard of 87mm sleeves but these are pushing it really thin.
if its a street car i wouldnt really go over 85 and 86 for a full out race car.
They have a closed deck design sleeves Darton, AEBS and Open Deck Golden Eagle.
very good idea if you want increased displacement or if you destory a block or just want piece of mind with your modified engine.
You can sleeve a LS block to 84mm and have the same displacement as a B20 since they have the same crank, so increasing the bore to 84mm gives you 2.0L just like the B20 cept you will have stronger sleeves and your block will say B18.
You can basicly do this on any honda block you can do this with a B16 resleeve it to 85mm run a GSR crank or LS crank for the small increase in stroke and you have a 2.0L engine in 1.6 clothing.
My choice for sleeves would be Darton, RS Macines, Golden Eagle Or AEBS.
For the 2.4L H22 im building 90mm sleeves 95mm crank
Old Jun 25, 2003
CIVIC2NV's Avatar
CIVIC2NV is an unknown quantity at this point
keep the LS
Old Jun 25, 2003
aznsmtboy's Avatar
aznsmtboy is on a distinguished road
if it has to be a choice between the C5 and the B20B VTEC.
I'd go with the B20B A friend of mine has a B20B in his DC2 and he's putting out about 508 WHP and 366 lbs/ft torque @ 18psi
click here for the dyno
I believed he ran a 12.9 on street tires with lower boost 14 psi, just read the thread in the link I provided above.
Old Jun 25, 2003
Chrissy's Avatar
Chrissy is an unknown quantity at this point
get the b20 block with the type-r head
Old Jun 27, 2003
03CIVICEX's Avatar
03CIVICEX is an unknown quantity at this point
i think his gay...
Old Jun 27, 2003
03CIVICEX's Avatar
haha JK!
Old Jun 30, 2003
iLLuMiNaTi's Avatar
what would happen if i'd have a B20B with a B16 head?
Old Jun 30, 2003
trashguy's Avatar
trashguy is an unknown quantity at this point
To be hones dont waste youe time with a B series engine because your going to end up spending a lot of money....
You want HP and Torque... get a JDM H22A Which is already VTEC and Turbo it... The Stock H22A deliver 190 Hp to the ground with a lot of room for mods. They H22A Type-S motor delviers 220Hp tp the ground which is respectful and still has room for a lot of mods.
I have seen H22As going for $1800 weher doubt you will find any B Series for under $2300 accpet mabey a B20 Long Block which isn't a complete motor.
My buddy had a 95 hatch with a h22a turbo and it was discustingly fast. i wish he got it dynoed.... Look up ther H22 though i think it would be a better route to go.
Old Jul 1, 2003
03CIVICEX's Avatar
get d17 civic motor
Old Jul 1, 2003
clownprince's Avatar
Ricerus Maximus
Get a F20, do a rear wheel drive conversion, a FR teg would be an awesome sleeper. Just as long as noone saw the pumpkin hanging down in the back.
Old Jul 1, 2003
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
To save money I would stick with his B18b LS bottom end and just swap a GSR B18C1 head. With the money saved from using your stock bottom end you could do some internal work or turbo it.
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
Black99Vtec
Jan 22, 2002 10:47 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
supercivic01
South
Nov 30, 2001 11:27 AM
