Resistor trick
Old Jun 22, 2003
MegaCivic2k1's Avatar
MegaCivic2k1 is an unknown quantity at this point
Resistor trick
Has anyone actually tried the Resistor trick in which it makes the engine think its receiving cold air constantly? I searched, but I found no one whose actually tried it.
Old Jun 22, 2003
slystad810's Avatar
What is the point of doing that?
Old Jun 22, 2003
dj pyrotechnics's Avatar
dj pyrotechnics is an unknown quantity at this point
supposedly makes the engine peform better cuz its thinking that its colder air (more oxygen)
Old Jun 22, 2003
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
Fooling the ECU into thinking it is sucking in colder/more/denser air than it really is is pointless. It would just make the car run richer, wasting gas and possibly causing cylinder leak-through in the long run.
Old Jun 22, 2003
Chrissy's Avatar
Chrissy is an unknown quantity at this point
the resistor trick is a way to make mad ca$h if you are good a fooling people
Old Jun 23, 2003
speedmi's Avatar
speedmi is an unknown quantity at this point
how would you make mad cash?by running rich? lol
Old Jun 23, 2003
Chrissy's Avatar
there are a bunch of gullible buyers out there and you can fool them into making it work. those sellers are fuggin makin me mad. i will start selling 3.3k resistors and see if it does me good. a chip?????? BS!!!
Old Jun 23, 2003
trashguy's Avatar
trashguy is an unknown quantity at this point
The resistor trick might work if you have a turbo or some sort of forced induction, but then you could also cause detonation and burn holes through your pistons.....
Just buy an AFC
Old Jun 23, 2003
AZD17A2's Avatar
AZD17A2 is an unknown quantity at this point
Is this the $2.95 "performance chip" you speak of??? Buy one and then it for me, that's about what it's worth.
Old Jun 23, 2003
R3DL1N3's Avatar
my friend spent $10 on his "performance chip" ...makes you wonder why hes iced up right now
Old Jun 23, 2003
R3DL1N3's Avatar
btw, ice = white pony
Old Jun 23, 2003
XxSoVeReiGNxX's Avatar
my bad wrong post haha sorry
Old Jun 23, 2003
cdmx's Avatar
btw the resistor sells for under a dollar at radioshack...And i have tried this and taken it off. All it does is makes your car run richer...no noticible gains with our cars sorry
Old Jun 23, 2003
cdmx's Avatar
hehe, yep i fooled some on ebay :P
But for some cars it actually helps a bit...Not our cars
Old Jun 24, 2003
Trying to fool your internal sensors by using lower or higher impedance resistors is a BAD IDEA. Use an impedance that is (a) too low or (b) too high and you run the risk of seriously messing up your motor. I don't even think there is even a fuse to protect you against (a). So if the resistance is too low and the resulting current fries some internal circuitry, then you're going to be up a creek.
The key to making more power is to force more air into your combustion chamber and have enough fuel to support the added airflow. That's it. Fooling the ECU into thinking it has more/colder/denser air is not going to do a single positive thing. Baaaad idea.
bowie
Jan 21, 2018 09:29 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
MamaBear2015
Sep 7, 2015 06:00 PM
hatch90
Sep 3, 2015 08:45 AM
