Rolling Back When Stopped?
Old Apr 9, 2003
JSpurgeon21's Avatar
JSpurgeon21 is an unknown quantity at this point
Question Rolling Back When Stopped?
I have an automatic and when I stop and let off the brake I have major issues with rolling back. And we're not talking on steep hills either. I haven't had any of my other auto's roll back like this one and was wondering if there was something I could do to fix it???
Old Apr 9, 2003
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
i'd look at the idle. my car is so f-d up and idles below 1000 rpm's. i don't know where to adjust it either, but if you turn it up it'll stop the roll back.
Old Apr 9, 2003
flotsamm's Avatar
Its suppose to idle below 1000 rpms, somewhere between 750 +/- 50 rpms I believe is the range you want.
If your talking about adjusting the throttle cable, becareful since if you make it to high your adding stress to your torque converter. It would be like doing a mini torque brake when your stopped.
I thought a saw a TSB or memo about the rolling back from Honda... hrrmph.
Old Apr 9, 2003
CuRiOuSfIsH's Avatar
Back From The Banned!
My mom's car used to do that, but only b/c the tranny kept going to neutral and drive on it's on... confused transmission
Old Apr 9, 2003
Grey's Avatar
DIY King
I don't have an automatic, but I always use the e-brake when I'm stopped on a hill. Why not just use the e-brake? I don't know how much of a hill an automatic 7th gen Civic can handle without rolling back, but there is a limit I'm sure. Use the e-brake. It might not be a problem, unless it changed since you bought the car. If it's always been like that then that's just the way it is.
Old Apr 9, 2003
Samari's Avatar
yea, use the ebrake if your praking on a hill. I dont think you would use your ebrake on a hill if you were still planning on takeing off. That would be really stupid. You can do it but why? Usually auto's dont roll back to much so you might want to go get that checked out at your honda dealership.
Old Apr 9, 2003
hassoomi's Avatar
i don't know if mine's normal--i hope so--but when i stop (and i have an auto) and then take my foot off the brake, i usually either inch forward or stay. there's this one small hill i stop at every day, and it's relatively steep (not exactly san francisco, but it's pretty noticeable). when i stop there, my car just stays. so i don't think it's normal for it to be rolling back if your not really steep. well, that's my experience. hope it helps
Old Apr 9, 2003
Grey's Avatar
DIY King
It's called a hill start and that's what they teach in driver's ed. You use it so that you don't roll back at all when starting on a hill.
Old Apr 9, 2003
MMILX's Avatar
MMILX is an unknown quantity at this point
yep, TSB about it somewhere... basically, its a low friction converter or something to that effect, so its normal for it to rollback... Kinda surprised me the first dozen or so times
Old Apr 9, 2003
HondaChic's Avatar
Civic Gurlies
HondaChic is a jewel in the roughHondaChic is a jewel in the roughHondaChic is a jewel in the roughHondaChic is a jewel in the rough
Mine does the same thing.
Old Apr 9, 2003
cambo's Avatar
I wish I was asian
eh...its a honda...what are you gonna do about a honda
Old Apr 9, 2003
Mbow's Avatar
Yea, the civic autos do tend to roll back kinda easily. It's completely normal.
Old Apr 9, 2003
Voiceofid's Avatar
End Bringer
mine does it too, i always thought it was because i beat the ish out of the tranny, did you know if you are going foward and you shift your car into reverse, it will not go on reverse until you hit about 5mph?
Old Apr 9, 2003
HomerSimpson's Avatar
Mine does it, dealer said it is normal on Civics and CR-V's
Old Apr 9, 2003
Hmmm, well I've had quite a few automatics before and I've never had it do this so bad before, so I just wanted to check and make sure what was going on. As for the TSB....what does that mean? Sorry, I'm new and don't know much about cars... =(
Old Apr 9, 2003
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
If im on a slight incline i can take my foot off the gas and sometimes it will either say there or start to roll back a little. I remember one time not too long after i got the car and i was on a huge hill i let my foot off the brake and before i could step on the gas i almost rolled back into the car behind me. I think its normal, unless your car will not go forwards or backwards like it always has then why worry about dumb things like this.
Old Apr 9, 2003
MMILX's Avatar
Its a Technical Service Bulletin (not a recall!)... so, basically its just a characteristic of the car... The TSB actually referred to a Honda newsletter mentioning this trait.
Old Apr 13, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
If you have an auto your car should NOT do that. I'd take it in and have it looked at.
Old Apr 13, 2003
ink's Avatar
ink
ink is an unknown quantity at this point
dude.. my auto rolls back too.. also one of my professor... hers roll back too
i dont know... if its not soemthing focking up, then i really dont care
Old Jun 24, 2003
zkasparks's Avatar
zkasparks is an unknown quantity at this point
try this, use your left foot for the brake when on a hill and ease up on it as you accelerate
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
trellex
May 24, 2015 04:39 PM
cruisers10
May 12, 2015 10:46 PM
crowtoo
May 11, 2015 06:50 PM
tylerginevan
Apr 27, 2015 12:29 PM
