## The Differences of Urethane and Fiberglass ##
Old Apr 7, 2003
vkylau's Avatar
vkylau is an unknown quantity at this point
Most Body Kit is made by Urethane or Fiberglass material, but what are there differences?
Which one is more easy to got scrash or break?
Which one is better?
And what are their other differences?
Old Apr 7, 2003
Jodster's Avatar
Post Whore General
Urethane is strong. If just as strong as your stock bumper. Fiberglass is Cheaper, but it breaks easier. IF you where to pull into a parking spot and go to close hitting the curb, you would more than likely crack the bumper. Urethane bumpers are flexable and will not crack on bumps and run ins with curbs.
But if anything does happen, fiberglass is easier to fix, yet urethane can not be fixed. I would go with urethane. With all of the pot holes and how low I would have my car, Its better to be safe than sorry.
Old Apr 7, 2003
GoOkStA's Avatar
GoOkStA is an unknown quantity at this point
get urethane...fiberglass will crack/break, urethane will not, urethane is better but cost more. u save more money wit urethane in the long run cuz u dont have to bondo/repaint it over and over if it keep breakin
Old Apr 7, 2003
RoadRunner's Avatar
yea thats basically it.
Urethane is stronger than fiberglass, it bends and flexes when you bottom or or hit things. More expensive and can't be repaired
Fiberglass is cheaper, and cracks and breaks easily if you hit something. Its also very easy to fix
it's your call on what material you want your kit to be
Old Apr 8, 2003
Dr5D's Avatar
fiberglass is also lighter weight, if your just in it for the speed. and quite a few kits dont come in urathane, at least not yet
Old Apr 8, 2003
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
the weight difference can't be that much. the urathane rear skirt for the xenon kit weighs very little for how big it is, i can't imagine how light a fiberglass skirt could be.
also, ak got the damaged xenon rear skirt from me and it looks like it's been repaired. what's up with that?
Old Apr 8, 2003
EEN's Avatar
EEN
EEN is an unknown quantity at this point
I think urathane is actually lighter. Think about it...sheets of fibreglass pressed together with a bonding resin....that is going to have to weigh more than a piece of plastic..........but anyways.......go with the urathane.
Old Apr 9, 2003
NytRyder2k2's Avatar
Bay Area
Go with eurethane....enough said
JetsterDajet
52
May 8, 2016 12:11 AM
General DIY
Sep 25, 2015 08:02 PM
speedlever
Sep 24, 2015 07:18 PM
TheRiddicles
Sep 21, 2015 01:28 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
