JDM K20a Engine Swap (higher octane req'd?)
Old Feb 18, 2003
cobrapimp's Avatar
cobrapimp is an unknown quantity at this point
I just wanted to do that as a title, before I get flamed for the swap title. I searched but couldn't find anything on having to use higher octane(100+) fuel in this engine. I heard somewhere that it would need that to even run. Does anyone know if it's true. Please shed some light on this. Thanks.
Mike
Old Feb 18, 2003
Drnknmnky13's Avatar
What octane did it require when it was in the RSX? Cause it wouldn't change.
Old Feb 18, 2003
Neonmike's Avatar
Neonmike is an unknown quantity at this point
I'm pretty sure that premium in your area would work. Here in the united states we take the average of research and motor octane, which gives a fuel's octane rating. I'm pretty sure that in japan they rate it only by one or the other, which is usually a much higher number than the average we use.
Old Feb 18, 2003
CarbonFly's Avatar
Related thread
I think you only need to worry about running higher octane if you are getting the Type R engine. The S should be same as any rsx in the states.
Old Feb 18, 2003
speed werx's Avatar
speed werx is an unknown quantity at this point
OK, ive posted bout this before... IT IS NOT 100 OCTANE........ the US equivlant is like 94/95 octane...... you can use 93 in the engien and it runs fine... as we are now.. but we will run 93 plus octane booster when needed in the swap car. any more Q's? email me please
Old Feb 18, 2003
cobrapimp's Avatar
I was referring to the Integra type R(k20a) not the RSX type S(K20a2) But I checked out those links and thanks MugenRacerX
Mike
Old Feb 19, 2003
speed werx's Avatar
Quote
[hr]Originally posted by: cobrapimp
Mike[hr]
i was talking about the k20a type R ...... NOT type S motor...
Old Feb 19, 2003
cobrapimp's Avatar
Mugen, I was actually talking about the post above yours by flyriceracer02. I guess I should have made that more clear. thanks for your info.
Mike
em2_k20a
May 19, 2015 03:36 AM
cloudguy
Apr 28, 2015 05:02 AM
shawe90
Apr 14, 2015 07:10 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
