-->Question about transmissions<--
Old Jan 14, 2003
AnchorBlueMan01's Avatar
AnchorBlueMan01 is an unknown quantity at this point
My mom has a 1998 Toyota Sienna. It has about 70,000 miles on it. She has has the transmission fluid drain and refilled with new fluid. Should she have the transmission fluid flushed now instead of just drained?? Is draining and flushing your transmission fluid that much different?? Thanks in advance
-AnchorBlueMan01
Old Jan 14, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
they should usaly do that
Old Jan 14, 2003
flotsamm's Avatar
The difference is the good shop will connect the tranny to a flush machine and flush out all the fluid and contaminants while the tranny is running. They should also replace the filter. This can be okay if you kept proper maintenance up on your tranny, meaning you had it serviced at scheduled maintenance times. If you didnt, you could be making it worse by flushing out all of the dirt that acted like a seal on the tranny internals.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
