Hyper whites in TYC?
The Legend
Anyone who has changed the bulbs that came with them to some hyper white one, did you change the little peanut one also? When I had my OEM headlights, I changed the parking light (peanut one) to a hyper white light, and it got all fogged up. Will this happen with the TYC's. Reason I'm asking is b/c if I change my lowbeams to a hyper white, I'd want to change the little peanut one also so that it will match. Any info would be helpful.
i think the "peanut bulb" is size number 194 i could find blue and red ones but when i got the blue one it turned green after awhile i took em out and changed it back to the stock bulb ALSO before changing any bulb always try not to touch the glass part of it and remember to wipe it with some rubbing alcohol or else it will burn out due to the oil from ur hands
i changed them to the blue hyper whites when i had my stock lights and it never fogged up
and now i have tyc's and use the same bulb and no fogging....
prolly your stock headlights werent sealed properly
Retired Super Mod and STILL Pimpin' Yo Mama
If you have TYC's its most like ly not the bulbs but in fact the assembly itself.. I've heard most TYC's have fogging tendencies.
I am currently in the process of resealing both of mine..
if you are going with a 194 bulb... get PIAA bulbs. They cost like 18 dollars for the set but they are very bright. I have them on my civic and my brother has them on his GTI. They don't turn green and they match hyper whites perfectly.
raymondxcho
Sep 29, 2015 09:00 PM
hondacivic0253
Sep 29, 2015 08:06 AM
