Ls vtec engine?
Old Dec 1, 2002
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
Ls vtec engine?
i just heard of this engine like 3 weeks ago. what car does it come in, what size is it, how many hp, torque, what r all the specs. thanks
Old Dec 1, 2002
JoeyTStyleS's Avatar
JoeyTStyleS is an unknown quantity at this point
it doesnt come in any car
its a vtec head with an ls bottom
Old Dec 1, 2002
cambo's Avatar
I wish I was asian
u just heard of it?!?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
its not an actual OEM engine. its a hybrid that people make.
on the B Series Engine, a head from a B16A could be put on the B18 block as well as the B20 block.
making one freaking nice engine.
Old Dec 1, 2002
amhtown01's Avatar
i heard it was a bottom of the line integra engine
Old Dec 1, 2002
Travii's Avatar
Travii is an unknown quantity at this point
Just like everyone before me said, it is the LS bottom end with a Vtec head, you can use any of the vtec series heads (b16a2, b18c1, b18c5) the b16 flows the best but people use all three. Hp is somewhere like 175 whp (only a guess acutally numbers may differ), torque...no idea. You can also have a b20 bottom end usually called a crvtec this one has more hp and more torque. Either way they aren't that reliable and have to be rebuilt after like 60,000 miles I believe.
Old Dec 1, 2002
SunnySideUp's Avatar
SunnySideUp is an unknown quantity at this point
My friend has the ls/vtec swap in his 2nd gen integra... it sucks. For the money its better to go with a different setup. It has less power than a stock B18C1. However B20 vtec is awesome.
Old Dec 1, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
Quote
[hr]Originally posted by: amhtown01
i heard it was a bottom of the line integra engine[hr]
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Dec 1, 2002
KiMcHi69's Avatar
KiMcHi69 is an unknown quantity at this point
this guy doesnt knw wat hes talkin about man.........[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG].....its an integra LS block....with a vtec head....common one would be the b16a head..
Old Dec 2, 2002
leadfoot78's Avatar
leadfoot78 is an unknown quantity at this point
It's called a Frankenstein motor. A well built lsvtec can get 200hp to the wheels with some type r internals. Not a project for the beginners.
Old Dec 2, 2002
JohnnyLee's Avatar
7thgen guh chee
I heard that they blow out really quick[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 2, 2002
Ya, my friend mis-shifted and over-reved and blew the motor...
Old Dec 2, 2002
AzNBonD's Avatar
AzNBonD is an unknown quantity at this point
if i were to go LS VTEC i'd turbo it for sure
it can be built awesome for high boost turbo
but some ppl say it's too much work and just go for a B18C1 built.
Old Dec 2, 2002
KiMcHi69's Avatar
y would u want to turbo an LS-Vtec motor ?????........when the compression is that high already...y not spend ur money on building the internals to handle higher boost on ur LS motor
Old Dec 4, 2002
Travii's Avatar
Quote
[hr]Originally posted by: KiMcHi69
y would u want to turbo an LS-Vtec motor ?????........when the compression is that high already...y not spend ur money on building the internals to handle higher boost on ur LS motor[hr]
Agreed. Don't boost a ls/vtec if you are going to boost do a stock LS motor, lots lower compression.
Old Dec 4, 2002
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
PACKAGE 6: IB Sleeved "Killer" LS B18B Block
Description: "I want power and durability." This is our most popular block. If you want to go turbo, this is a good choice. If you want to go all-motor and make 220+ whp and run higher octane this is your choice. This block features the following details:
Iron Sleeves for total strength and durability
IB Spec Wiseco Pistons, JE pistons, or Arias Pistons. You choose!
Eagle Rods or Probe Rods
Bore, Hone, Hot tank, Deck (if nec)
Balanced Crank
Polished Crank
All new Bearings & Thrusts
All new seals, and Oil pan Gasket
New VTEC oil pump
New VTEC water pump
LS/VTEC Oil line Kit with all fittings
Compressions come in 9:1, 9.4:1, 10.5:1, 11.8:1, 12:1, 12.5:1. 12.8:1, 13:1
Price: $3450 Shipped. These are the same sleeves people use to boost 35+ PSI. Very strong.
Just one good example for how to properly set up an LS/VTEC motor (a "Frankenstein motor" is a B20 block/B16/18 series head BTW, someone was wrong about that).
And it’s actually better to run high compression with your boost. Power wise anyway. If tuned properly these engines will create more usable HP and lower boost settings (by far) then their higher PSI, lower compression counterparts. There of course comes a point at which the 2 curves intersect and more PSI and lower compression becomes the only viable option, but were talking over 22 PSi here. Not your typical street set up by far. Then again, if you are a n00b with cash and just want a no hassle turbo set up without needing to tune it often (which is retarded BTW) a lower compression, low PSI set up is for you, as not to screw your engine up with your incompetence.
BTW you can order that engine, or see others at
import builders
Old Dec 4, 2002
cambo's Avatar
I wish I was asian
Quote
[hr]Originally posted by: SunnySideUp
Ya, my friend mis-shifted and over-reved and blew the motor...[hr]
cant you blow any, if not most, motors like that...
MamaBear2015
26
Apr 16, 2015 11:08 PM
Grey
16
Jan 27, 2002 11:34 PM
AznSaint
Jan 8, 2002 12:58 AM
joefufu419
Bolt-on Engine Performance
Jan 7, 2002 09:18 PM
BamBam
Dec 8, 2001 02:21 PM
