URGENT: Help with wiring.
Old Nov 26, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
I am currently wiring a headunit intoa car. here is aproblem im hoping someone can help me torubleshoot:
Everything is wired together except for the power wires
when u hook the power wire from the harness to the HU nothing happens
when u hook the power wire from the harness into a speaker wire from the HU there is power to accesorries but no power to the HU
when u hook the power wire from the HU into the abovementioned setup the HU now also has power, but the speakers do not function.
Speaker wires are all wire correctly.
The ground seems to be wired correctly.
ANy input on why this is not working,
thanks in advance.
Old Nov 26, 2002
Da1lyDr1ver's Avatar
i've read on the forums that you need to have the yellow memory wire hooked up so it has power going to it, if this isnt hooked up then the head unit wont work, try that, but thats all i know. [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Nov 26, 2002
01civic911's Avatar
01civic911 is an unknown quantity at this point
yeah, there should be a red and a yellow that need to be twisted together then bonded with the power wire, its like the remote wire for amps, the amps wont work without that wire, it acts as a relay to tell the head unit when the vehicle is on and when it is off, so it knows to turn off.
Bruce2
Sep 27, 2015 08:45 PM
Gsxtacy
Sep 12, 2015 01:09 AM
michael0219
Sep 1, 2015 10:25 PM
sch2cm
Jul 21, 2015 09:58 PM
