Gear Ratios for Civic 7th gen LX and EX
Old Oct 29, 2002
freestyle's Avatar
freestyle is an unknown quantity at this point
Hi all,
I tried searching here, and also looking on Honda web page, but nobody has the gear ratios for 7th gen Civic LX and EX
Based on gear ratios of 1st, 2nd, 3rd, 4th, 5th and the final gear ratio, I can plot some graphs and determine the optimal shifting points if I can find a dyno graph too.
Anybody.....
Old Oct 29, 2002
freestyle's Avatar
Also,
What is REDLINE RPM for LX and EX?
Old Oct 29, 2002
Ichiban's Avatar
Ichiban is an unknown quantity at this point
The Ex ratios are the same as in japan so go to the japanese honda site and they will tell you. www.honda.co.jp. You will need a translator just go to altavista.com. The rev limiter on the Ex is 7000 Not sure about the LX
Old Oct 29, 2002
Atlantis's Avatar
Atlantis is an unknown quantity at this point
1st: LX: 3.461, EX: 3.142
2nd: 1.869
3rd: 1.241
4th: 0.969
5th: LX: 0.710, EX: 0.756
Rev: 3.230
Final Reduction: LX: 4.111, EX: 4.411
Hope This Helps. 2nd, 3rd, 4th, same for both models. Enjoy!
Old Oct 29, 2002
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
I never knew they were different, thanks.[IMG]i/expressions/beer_yum.gif[/IMG]
Old Oct 29, 2002
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
I've known they were different since before I bought the thing.
Anyhow. they both redline at 6800RPM, limiter at 7grand.
Old Oct 29, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Can someone answer me this? Are the EX coupe gear ratio's different from the EX sedan?
I ask because I raced against my friend with i/h/e and cat-converter when I just have an intake. I have the coupe, he has the sedan, both EXs. We ran twice and I had 1 perfect launch and 1 near perfect launch. When we raced, by the time I was out of 1st gear, I was nearly a full car length ahead of him. He told me the gear ratios in the EX coupe are shorter than the sedan's. Can anyone verify this for me? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 29, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
Quote
[hr]Originally posted by: SoNiCcIvIc
I ask because I raced against my friend with i/h/e and cat-converter when I just have an intake. I have the coupe, he has the sedan, both EXs. We ran twice and I had 1 perfect launch and 1 near perfect launch. When we raced, by the time I was out of 1st gear, I was nearly a full car length ahead of him. He told me the gear ratios in the EX coupe are shorter than the sedan's. Can anyone verify this for me? [IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
The coupe and sedan both use the same drivetrain, so no there is no difference between the gear ratios.
Old Oct 29, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
Quote
You won because you have a coupe and it's a lot lighter than something with 4 doors. [IMG]i/expressions/face-icon-small-smile.gif[/IMG] Common sense there.
Old Oct 29, 2002
Hawk's Avatar
You boost, I-VTEC
Quote
[hr]Originally posted by: nytejade
Quote
You won because you have a coupe and it's a lot lighter than something with 4 doors. [IMG]i/expressions/face-icon-small-smile.gif[/IMG] Common sense there.[hr]
OOH OOH!!! and i call you out. According to Hondas website Hondacars.com
03 EX Coupe 2554
03 EX Sedan 2601
that don't seem like alot to me?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 29, 2002
And besides, if the coupe's gear ratios were shorter, the sedan would actually beat you off of the line. But once you get into late 2nd, early 3rd gear, you would start to pull on him.
This is all a moot point anyways since the engine and transaxle are identical between the coupe and sedan.
Old Oct 29, 2002
freestyle's Avatar
thanks guys for the info
Old Oct 29, 2002
CapYoda's Avatar
Escaped Convict
you took him cuz his I/H/E ate away his low end...
if you were stock, you would have got a better jump on him too.
Old Oct 29, 2002
Mbow's Avatar
Basically, your friend doesn't know how to launch his car. That's all that happened.
EDIT: I see the weight numbers have changed for 2003. The coupe used to be about 2550 and the sedan was like 2564 or something similar to that. I wonder why the gap has opened up so much more for 2003?
Old Oct 30, 2002
SoNiCcIvIc's Avatar
Quote
[hr]Originally posted by: Mbow
Basically, your friend doesn't know how to launch his car. That's all that happened.[hr]
That was the first thing I was thinking. I was kinda hoping his mods would do something. Once before we raced from a 40MPH roll up to about 80MPH and by the end of the race I was 1 car length ahead of him. I could hear us shift gears simultaneously now that I think of it. For that race, he had I/H/E (custom exhuast) while I had just an exhaust (Skunk2).
Heh... I think I might just keep my intake as a solitary mod under the hood of my ride for a while. CAI.
j/k [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Oct 30, 2002
Mbow's Avatar
Quote
Quote
j/k [IMG]i/expressions/face-icon-small-wink.gif[/IMG][hr]
Well, I don't know what to say about that. There's no way you would be ahead by one car length if he knew how to launch the car even half decent. However, the rolling race is a little interesting. Maybe he didn't shift back down to second and went to third. He could have shifted to second, then to third, and finally to forth instead of holding out in 3rd. He could have also shifted very slow and very abruptly instead of smoothly. You could have one of the faster vics that came off the line. etc...
Then again, the coupe could really be faster. I don't think so as everything is pretty much the same besides the obvious.
My best guess is that you are a pretty good driver and he isn't. Simple as that if you ask me.
Lastly, what you ought to do is this: switch cars and race again, if you trust him with your baby. LOL I would be very interested in hearing how that turns out. So, when you get a chance, drive his and see what happens. My vote is own you no matter what car you're in...Be absolutely certain you let me know what happens if switch cars and race though...ok..pm if needed..
Old Oct 30, 2002
SoNiCcIvIc's Avatar
Quote
[hr]Originally posted by: CapYoda
if you were stock, you would have got a better jump on him too.[hr]
Old Oct 30, 2002
WeakVTEC's Avatar
WeakVTEC is an unknown quantity at this point
Um, I gained torque on the dyno with I/H/E, how does it eat away low end?
Old Oct 30, 2002
Mbow's Avatar
Freeing up the airflow in and out of the engine does eat up the low-end torque. It shifts the curves upward and to the right. I feel like I am in econ class...
However, a good driver can compensate for this. It's all in the launch. If you can get a good launch and not bog, a stock will loose aganst a vic with i/h/e everytime - all other variables held constant. Once out of first, the rpms stay high which is exactly where the i/h/e combo adds the power.
It's just much easier for the inexperienced driver, anyone for that matter, to get a good launch off a stock car than one with bolt-ons.
Just remember this: i/h/e adds top-end power at the expense of low-end torque. A stock vic will be easier to launch and maybe just a hair quicker off the line. however, after 1st gear the engine will stay in the upper rpms and will be fighting aganst restriction for the rest of the race. The bolt-on vic will be harder to launch and maybe a hair slower out of first, but will be in the upper rpms for the rest of the race where the bolt-ons shine. So, the bolt-ons sacrifice bottom-end but you are only using the bottom end for a second as you launch...hope that makes sense...
Old Oct 30, 2002
SoNiCcIvIc's Avatar
I see...
It still depends on where/how you start/launch your car.
When I raced my friend, he didn't gain at all on me. We shut down entering 3rd gear instead of 4th.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
EC3
Apr 22, 2015 07:55 PM
Rardon6thgenCiv
Apr 15, 2015 07:37 PM
Myredjonda
Apr 14, 2015 07:00 PM
brill
Nov 12, 2001 07:29 PM
