Engine Codes and VTEC-E Confusion
Old Oct 27, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Just an FYI for everyone out there. Seems to be the general consensus that the EX comes with VTEC and the HX comes with VTEC-E. To set the record straight they're both the same. The HX merely adds the ability to lean-burn...which is why it has an A/F Ratio sensor (like the Si & RSX).
The VTEC in the EX is also VTEC-E. Here ya go:
2002 Honda Civic DX: 1.7L SOHC 16-valve I4 ULEV-certified engine (D17A1)
2002 Honda Civic LX: 1.7L SOHC 16-valve I4 ULEV-certified engine (D17A1)
2002 Honda Civic EX: 1.7L SOHC VTEC-E 16-valve I4 ULEV-certified engine (D17A2)
2002 Honda Civic HX: 1.7L SOHC VTEC-E "Lean Burn" 16-valve I4 ULEV-certified engine (D17A6)
Old Oct 27, 2002
Aaggie77's Avatar
Aaggie77 is an unknown quantity at this point
If the HX has the a A/F sensor as the Si and RSX, can it be tweaked to perform better or overridden at least.
Old Oct 27, 2002
PESTLNC's Avatar
I was thinking the same thing actually. If we could get a competent chip programmer to do it then I'd say yes, but it's doubtful that will ever happen. No one buys an HX to "go fast".
Old Oct 27, 2002
Aaggie77's Avatar
Well, guess who did. I got it a good deal from a dealership w/ 12k miles on it. Only $10,800. I thought I was getting a deal.
Old Oct 27, 2002
PESTLNC's Avatar
I have an HX also...you get the 5-speed or CVT?
Old Oct 27, 2002
Aaggie77's Avatar
5-speed.
Old Oct 27, 2002
PESTLNC's Avatar
Good, you can add power adders to the HX 5-speed w/o worry. CVTs need to be beefed up to handle higher output. There's a couple members here that have added I/H/E and nitrous with good results.
Old Oct 27, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
Quote
[hr]Originally posted by: PESTLNC
2002 Honda Civic HX: 1.7L SOHC VTEC-E "Lean Burn" 16-valve I4 ULEV-certified engine (D17A6)[hr]
Every car has an A/F ratio sensor (primary O2 sensor). It's just that the 7th gen HX uses the same part and relay as the RSX.
Old Oct 27, 2002
PESTLNC's Avatar
Hmmm, I was under the impression that the HX had either an additional one or knock sensor. I could be wrong. I'm trying to learn as much as possible about the lean-burn system, and it just seemed obvious to me that Honda would use something to prevent predetonation from leaning it out too much.
tylerginevan
Apr 27, 2015 12:29 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Jr
Dec 1, 2001 09:20 PM
CapYoda
Nov 11, 2001 05:17 PM
civicPesek
Nov 7, 2001 11:33 PM
