Wheel hop?
Wheel hop?
All right does anybody know of anybody products to get rid of that annoying right wheel hopping that goes on if that tire breaks free on the road??
Thanks guys and girls
Joe
Joe
i know what you mean -- i have a real fun road to drive by my house winding turns and dips. every morning when i'm late and ripping up the road i get that noise -- this morning too. it just makes me want to put a rally kind of suspension in the car, thats what i'm doing in the spring
I think if you replace all your rubber bushings to urethane bushings it will help, but I'm not sure if there are any bushing kits out for our car besides the neuspeed front sway bar bushing kit. I have that kit, and I've noticed a little less wheel hop than before. It'd be nice to change out other bushings too....
good tires are ok but even during the summer if I rip a burnout or get a nasty launch with too much wheelspin the whole right side of the car starts to feel like it is hopping. It makes this loud banging noise like the wheel is acutally getting air then coming back down hard. I am just trying to get that corrected, it even happens with my Nitto 555's.
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
yes, its called wheel hop. this is caused by the engine/transmission rocking back and fourth in its mounts when you are trying to put down more torque then it was designed for at launch (ie dropping the clutch at 5K). A simple fix, if they make them for you, is to get energy suspension motor mount inserts. this will stop the motor felxing and allow you to put the power to the ground. I can launch at any RPM i want, on or off nitrous and i dont get any hop.
The only thing that will truelly get rid of wheel spin/hop, is a new differential. This is due to the fact that all the HP is going to the wheel that doesn't need it.
Currently nobody makes one for the 2001+ civic. But if quaife did make a helical LSD for our cars, that is what you would get.
Sorry, but you just might be stuck with this one. Also, from my experience as an autocrosser, if you're getting wheelspin/hop during a turn, you're may be entering the turn to fast, and/or trying to turn to hard for the chassis and tires to handle.
DIY King
One other thing you may want to try is this: oem part?
It helped me out. Maybe not all that much as initially posted, but it's a definate improvement. Cheap too, so you might as well get it.
Quote
[hr]Originally posted by: Simkin
Sorry, but you just might be stuck with this one. Also, from my experience as an autocrosser, if you're getting wheelspin/hop during a turn, you're may be entering the turn to fast, and/or trying to turn to hard for the chassis and tires to handle.[hr]
Think about it this way, like I said wheel hop is due to the engine/tranny torqing back and fourth in its mushy stock mounts (this doesn’t happen on RWD cars, they get axle tramp, which is different). How is an LSD going to do anything to counteract that? The ONLY application I could see in which this would be the case, is when too much torque is loaded into a open differential equipped FWD car in a turn, and the inside tire just spins, causing wheel hop. Again, whoever this would be eliminated by the motor mount inserts. Splitting the torque to the outside wheel as well will only lessen the problem, not cure it.
I don't doubt the fact that upgraded mounts would help. Personally, I will admit that there are things that I don't know, from lack of experience.
But I don't drive straight line, and probably never will. My aspirations and experience come from autocrossing, where how you turn is what makes a difference. I'm quite sure that a LSD would help straight line aswell, but you're probably right; maybe not enough to matter.
But for real racing, by sending the HP & torque to the wheel that doesn't have traction, that wheel will spin, which is what happens on a stock differential. On an upgraded helical LSD it would instead transfer that HP & torque to the wheel that has the most traction. Which drastically reduces wheelspin, and also allows for higher exit speeds on turns.
man, at first I thought he was talking about wheel hop during turns. The answer for that would be a front strut bar.
