b18c or h22a?
Old Oct 18, 2002
sauado's Avatar
sauado is an unknown quantity at this point
b18c or h22a?
which one is better coz they both 200hp stock
but h22a is way cheaper
i know many ppl will do a b18c but i duno wat the diff
Old Oct 18, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
H22A of course[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
oops read it wrong, i thought u said K22, then that case of course B18
Old Oct 18, 2002
ExRacer's Avatar
ExRacer is an unknown quantity at this point
b18c usdm is only 170 hp, where do u get 200 from? unless ur talking about b18c5 which is the type r motor thats 195 hp usdm.
Old Oct 18, 2002
JohnnyLee's Avatar
7thgen guh chee
I love Integra's so I would pick a B18C over a H22 any day.
Old Oct 18, 2002
aZnVoYCe's Avatar
Quote
[hr]Originally posted by: ExRacer
b18c usdm is only 170 hp, where do u get 200 from? unless ur talking about b18c5 which is the type r motor thats 195 hp usdm.[hr]
Yup! There's no B18C in 200 hP. To answer your question, H22A
Old Oct 18, 2002
Travii's Avatar
Travii is an unknown quantity at this point
The difference is size, weight, HP and displacement.
The H22 weights about 80 lbs more than the B Series I am pretty sure.
The H22 is bigger in terms of everything pretty much.
The H22 has 5 more HP stock than the highest B series (b18c5)
The H22 displaces .4 liters more than the b18 which means more potential.
The B18c5 comes with a stock limited-slip differential which is really nice but you can get an H22 with an OEM one if you JDM I am pretty sure.
The h22 is MUCH better and you will be able to do more with it, the B series is becomming much more expensive because everyone that has a honda wants one, so demand is much higher. The bad side of the H22 is fitting it into a car. Fitting it into any Civic is difficult the 93-95 hatchbacks are pretty easy from what I have read but don't think about putting it into a 7th gen without major body work.
Old Oct 18, 2002
dragoon's Avatar
any civic needs major bodywork, even the 92-95 hatches - it's just that they've already figured out how to do it on those cars
Old Oct 19, 2002
criminal's Avatar
criminal is an unknown quantity at this point
h22 owns and more hp than the b18c
Old Oct 19, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
Quote
[hr]Originally posted by: dragoon
any civic needs major bodywork, even the 92-95 hatches - it's just that they've already figured out how to do it on those cars[hr]
Not true, with the mount kits out most of these motors including the H and B's are drop ins on 5th and 6th gens. Its just the wiring that is a pain.
Old Oct 19, 2002
mohawkboom's Avatar
well..going into which car?...staying N/A or plan on boosting it?...
the H22A drops into 5th and 6th gen vicis..but requires completely neew engine mounts and wiring..the B18's just drop in..plug and play....
the H22A (vtec) has more potential..and more starting HP. but weighs over 130lbs more with transmission and changes the center of gravity on the car. The B18C1 (gsr) is very close the weight of the D series in the civics of any gen. it's also historically a tougher engine. Many H22's burn oil and such after 50-70k..B18's can be driven hard for 100k before you need new rings and bore the cylinders again..
If you want to be original and stay cheap. Get a B20Z (CR-V) and buy some Type-R B18 heads...just than gives you 183 Horsies at the wheel using a 5th gen platform...and it'll be cheaper than getting a B18c1 [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Frankenstein!!!
Old Oct 21, 2002
DaCurryman's Avatar
DaCurryman is an unknown quantity at this point
I was just wondering where would be a good place to learn all about the different engine's that Honda's come out with, 'cause thos whole swapping/hybrid concept is very interesting, and if I learn enough, I might just try it one day. =)
anubis62
Sep 27, 2015 12:56 AM
yyyktk1
Sep 12, 2015 04:02 PM
NROD315
Sep 12, 2015 02:46 PM
NROD315
Sep 4, 2015 09:22 PM
NROD315
Jul 21, 2015 07:46 PM
