Almost died workin on the Civic this afternoon.
Old Sep 2, 2002
SLeePeR012's Avatar
SLeePeR012 is an unknown quantity at this point
Long story but its good advise...A simple precaustion can save ur life...I MEAN IT!
This afternoon I was rotating my tires... I cris-cross them so I did my Front passenger and Rear Driver first... no problem. I was using two Honda jacks one off each civic owned in my family (jus to say this off hand now..Honda jacks[IMG]i/expressions/face-icon-small-mad.gif[/IMG][IMG]i/expressions/face-icon-small-mad.gif[/IMG]) I put a jack under the front driver and one on rear passenger and I took off the rear passenger rim and im gettin gettin ready to take off the front driver's rim when I hear a BOOM! and my car is on it's rear/right chasis. I work fast and put the jack under my rear tie bar and I take off the front jack and put it under the rear passenger and started to jack it up when my car started to lean towards me then and I ran from my car to my mail box which is made of concrete and I took off a few blocks, the blocks were already loose, not like I broke em. I put them under my rear passenger and the car is stable..Im now under the rear passenger side next to the concrete and im tryin to jack up the tiebar's jack because I couldnt get enough clearance from the back of the car to turn the jack to go up, my right side was too low for me to fit then I notice my ride leaning really bad and I close my eyes and I hear another BOOM! I open my eyes to see my exhuast pipe is pressed aganst my forehead, I swivle out of there and saw one of my three concrete blocks crushed so I jack up my driver's side rear and take off my tie bar's jack and put it under my rear passenger using the conrete I had not to hold it up but to keep it straight so it don't move, this works and my rim is back on. NO DAMAGE. My axle went right into my driveway makin a huge dent and my car literally turned 45 degrees fomr when I started. My advise is always work wit someone and have jackstands to hold up not jus jacks or even concrete and DO NOT WORK ON slainted driveways.
Hope ur day was as happy as mine.
Be careful!
Lou-
Old Sep 2, 2002
spoiledsteph
Guest
Posts: n/a
isn't it common sense not to jack up a car on a slanted driveway? hmmm.......i think it is.....but then again, that is the problem with lotsa people today...no common sense. good thing that you didn't get hurt, but next time lets think about a little thing called gravity. then you wouldn't have this kinda problem....
Old Sep 2, 2002
GOTSPRINGROLLS's Avatar
Super Member
GOTSPRINGROLLS is an unknown quantity at this point
dayam meh! got to count ur motha-fvckin blessings!
Old Sep 2, 2002
SLeePeR012's Avatar
my driveay isn't slainted.... My adivse is don't work on a slainted driveay... I never said I had one...
Lets not make things up
Old Sep 2, 2002
woohooh00's Avatar
woohooh00 is an unknown quantity at this point
are you dumb? where is your level working surface, and where are your jack stands?
Old Sep 2, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
anyone could have told you that u needed jackstands, NEVER EVER SUPPORT A CAR WITH ONLY THE JACK. not to flame but seriously the stuff you described to us was common knowledge. it even says on jacks to use jackstands. and the slant thing is also self explanitory. i hope you learn from your mistake, and i hope that all people on this board use extreme caution when working under a 2500 lb vehicle.
Old Sep 2, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Dayum Steph, did you take your midol today? J/K
You do have a point. I'd never do it on an incline, always on level ground and put a rock or something behind a tire...It's a good thing you didn't get hurt man.
Old Sep 2, 2002
Toad's Avatar
Toad is an unknown quantity at this point
Quote
[hr]Dayum Steph, did you take your midol today? J/K [hr]
lol [IMG]i/expressions/laugh2.gif[/IMG]
...she's gonna be pissed...
Old Sep 2, 2002
Royando's Avatar
Royando is an unknown quantity at this point
theres a tire shop around the corner where i got my tires and i go there when ever i want anything, i rather bother someone a lil bit and not take the chance of screwing up something. you just never know what will happen when couple tons car is up in the air. specially on slanted driveways.
glad your ok though Bro.
Old Sep 2, 2002
SilverSactoCiv's Avatar
SilverSactoCiv is an unknown quantity at this point
Dood, you should've used your spare in place of each tire.... either that or got 4 jackstands (my recommended way).
If you wanna be lazy, do it safely!!!!!!
Old Sep 2, 2002
STYLIN2K2's Avatar
STYLIN2K2 is an unknown quantity at this point
That would make you a JACKA$$...lol...lol get it... Jack- A$$ [IMG]i/expressions/laugh2.gif[/IMG]
Old Sep 2, 2002
Macko's Avatar
Macko is an unknown quantity at this point
you car wasn't balanced... if you plan to take all four wheels off the road... you use 4 jacks...
Old Sep 2, 2002
SLeePeR012's Avatar
...I dont have a slainted driveway!!@# It was jus an advise guys. And I do take donations for jack stands otherwise I've never had any trouble rotating my tires before using two Honda jacks.
Old Sep 2, 2002
fraga's Avatar
Wicked Moderatuh
Dude, you should have bought a Lottery ticket....cause you were the luckiest ***** f.ucker that day...
Old Sep 2, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
not to sound really f'ing stupid to all of u but i personally when i change the tires like rotate them i use the spare. I rais one side and take off 1 tire then i put the spare on that. then i lower the car go to the other side raise that up tehn i take off that tire off and put the tire from the other side on there and i lower that side and then i raise the side with the spare and I take off the spare and put the tire from the other side on that side. and vis versa. I know it take awhile but then u catn F'up unlkess u dont put the lugs on then ur jsut an idiot.
Old Sep 2, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Uhhh Yeah........ I'm gonna have to go ahead and tell you to use Jackstands next time. That would be ggrrrrreat. Mkay?
I thought it was common sense not to leave a car raised up on jacks... It says right on my jack "Lifting mechanism" do not leave car raised on jack."
Old Sep 2, 2002
Quote
[hr]Originally posted by: Toad
Quote
...she's gonna be pissed...[hr]
No love lost...She's one of the coolest ppl on this site, I'm sure she'll just laugh since I meant it as a joke. Right cutie! [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Sep 2, 2002
JohnnyLee's Avatar
7thgen guh chee
Hearing incidents like that does not want me trust jacks at all!!
Old Sep 2, 2002
StraightEdgeCivic's Avatar
StraightEdgeCivic is an unknown quantity at this point
what about ramps? are those safe?
Old Sep 2, 2002
spoiledsteph
Guest
Posts: n/a
Quote
[hr]Originally posted by: silverdevil
Quote
Quote
No love lost...She's one of the coolest ppl on this site, I'm sure she'll just laugh since I meant it as a joke. Right cutie! [IMG]i/expressions/face-icon-small-wink.gif[/IMG][hr]
nah...silver's right...i am pretty cool haha. anyways silver to answer your question, i musta missed my daily dose. that could explain why noone has called to hang out today...[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG] thanks for pointing that out....hehe
Old Sep 3, 2002
midvis's Avatar
Vic On Dubs
midvis is an unknown quantity at this point
Ramps are safe but...... How do you plan on taking off your wheels to rotate them when they are sitting on ramps?
please explain[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Sep 3, 2002
AceKicker's Avatar
good catch midvis i just noticed that too.
Old Sep 3, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Glad to hear you made it out of that ALIVE.
and if you EVER need to work on your car like that again, I have a floor jack and 4 jackstands. You can come over and use 'em, just shoot me a PM. Orland isn't that far.
Old Sep 3, 2002
Quote
[hr]Originally posted by: spoiledsteph
nah...silver's right...i am pretty cool haha. anyways silver to answer your question, i musta missed my daily dose. that could explain why noone has called to hang out today...[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG] thanks for pointing that out....hehe[hr]
If I weren't so far away (on the other side of the world) I'd hang out with ya! As long as you don't mind hanging out with a Domo-Kun looking motherfvcker!
Old Sep 3, 2002
spoiledsteph
Guest
Posts: n/a
Quote
Quote
If I weren't so far away (on the other side of the world) I'd hang out with ya! As long as you don't mind hanging out with a Domo-Kun looking motherfvcker! [hr]
what is up with all this domo-kun stuff??? why does everyone have the pics and whatnot? i don't get it...
McD
Apr 29, 2015 03:50 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
twtron
Apr 17, 2015 12:09 AM
McD
Apr 16, 2015 10:46 AM
silvervtec01
Nov 4, 2001 06:56 PM
