NITROUS nozzel sises?
Old Aug 12, 2002
Barney's Avatar
Barney should not be trustedBarney should not be trustedBarney should not be trusted
Any nitrous kit?
Are the nozzel settings for nitrous kits all the same? The fuel jet and the nitrous jets, are what I am asking about. I lost my sheet fot the nozzel settings. I have a Nitrous Express kit and would appreciate it if someone could give me the jet sizes of each horsepower shot.
1. 25 shot
2. 50 shot
3. 75 shot
4. 100 shot
5. 125 shot
I usually use 50 or 75 but I was just curious as to what they all were so I can change my shot. Thanks in advance.
Old Aug 12, 2002
SlvrEX5spd's Avatar
SlvrEX5spd is an unknown quantity at this point
have you ran a 75shot on your civic? any probs? what about your clutch, have you upgraded it? peace....
Old Aug 12, 2002
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
i only know these four
35 shot n2o=31 fuel=18
50 shot n2o=35 fuel=20
75 shot n20=41 fuel=24
100 shot n2o=52 fuel=33
SlvrEX5spd im running 75 shot for over a year nowand car still runs good.you just have to know how to use it right.clutch almost needs to be replaced.
Old Aug 13, 2002
Havok2k1's Avatar
Wicked Pissah Admin
It depends on the displacement of the motor that you use. It's all based on A/F ratios vs. nitrous flows. The best bet would be to contact the manufacture of the N2O system and they should be able to give you the info that you need.....
Old Aug 14, 2002
silvergts's Avatar
silvergts is an unknown quantity at this point
i was told by aa NX tech that a rule of thumb for nitrous, is that you can spray half the crank horsepower safely. like if your car has 120 hp stock, you can spray a 60 shot and it should run fine with no problems. of course it isn't the rule, but a decent way to measure. Now remember, this is measured by CRANK hp #'s. NOS is measured at the crank, while NX is measured at the wheels. just try to remember that.
Old Aug 28, 2002
RZRSHRP's Avatar
RZRSHRP is an unknown quantity at this point
Quote
[hr]Originally posted by: silvergts
i was told by aa NX tech that a rule of thumb for nitrous, is that you can spray half the crank horsepower safely. like if your car has 120 hp stock, you can spray a 60 shot and it should run fine with no problems. of course it isn't the rule, but a decent way to measure. Now remember, this is measured by CRANK hp #'s. NOS is measured at the crank, while NX is measured at the wheels. just try to remember that.[hr]
No, NOS rates at the wheels not the crank.
ttamrekab
Sep 28, 2015 01:22 AM
crowtoo
May 11, 2015 06:50 PM
CIVICINJEN
Mar 18, 2002 11:23 AM
supermex
Feb 1, 2002 09:05 AM
ZZCIVIC
Detailing
Jan 24, 2002 01:21 AM
