Need a brainstorm here...
Old Jul 26, 2002
WD40's Avatar
WD40 is an unknown quantity at this point
I don't know how many of you guys suffer from this too, but when I have my A/C fan on full blast the vents won't stay where I point them. Unless it's pointed perfectly straight it always ends up pointing all the way to one side.
I've been trying to think of some DIY to fix this annoying little defect, but I haven't come up with any brilliant revelations.
I though of pulling the vents out and putting a dab of rubber cement in strategic locations, but I figure that would probably just pull the vent back to whatever position it was in when the glue was applied.
Basically I need to figure out how to stiffen the vent up. Any ideas?
Old Jul 26, 2002
Kung's Avatar
Kung is an unknown quantity at this point
Do you mess with the vent a lot? I can put mine on full blast and it stays in position. Maybe you can put one of those air fresheners that fit on the vent slider that way there will be more weight to keep the vent position in one place.
Old Jul 26, 2002
noypirider's Avatar
noypirider is an unknown quantity at this point
i suggest you go to your dealer and have it fixed. tell them you have a loose vents.
Old Jul 26, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
i have the same problem.... stick paper between the cracks?
Luluharp
Sep 27, 2015 11:56 AM
jnissen
Aug 9, 2015 05:34 PM
jzhartman
22
Jul 23, 2015 10:42 PM
SoNiCcIvIc
North Cali
62
Jul 6, 2002 03:02 PM
