howstuffworks is wrong about a camshaft statement
Old Jul 17, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
i was just reading right now about camshafts and they were explaining how an inline 4 or inline 6 will only have one cam since there is only one head. WRONG!!!! let's see, can you say type r or s2000?????
edit: Jon 1 howstuffworks 0 muhahahahahahaha (sorry i'm bored[IMG]i/expressions/face-icon-small-cool.gif[/IMG] )
Old Jul 17, 2002
ZRPM's Avatar
ZRPM is an unknown quantity at this point
SOHC will have one cam, DOHC will have 2. They are still sort of correct I think.
SOHC 2 valve per cylinder - the intake/exhaust cams open 1 valve each
DOHC 4 valve per cylinder - again, the intake/exhaust cams open 1 valve each
Pop quiz boys and girls, how does a SOHC 4 Valve Per Cylinder Engine work [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Jul 17, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i am not famaliar with this topic hehe.
Old Jul 17, 2002
Cypher's Avatar
Cypher is an unknown quantity at this point
SOHC 4 valves per cylinder intake and exhaust open 2 valves each ? am i right ? i dunno
Old Jul 17, 2002
SlvrEX5spd's Avatar
SlvrEX5spd is an unknown quantity at this point
our engines as well as many others have 2 intake valves and 2 exhaust valves...times 4 cylinders is 16 vales and 4 per cylinder [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 17, 2002
ZRPM's Avatar
It uses a rocker arm to use one cam to lift 2 valves. This creates a loss of power through friction (heat)
The old, dare I say inefficient, pushrod design uses a single camshaft with pushrods and rockers to operate 1 valve per head in the V configuration engines.
All in all, 1 cam per valve is the best design and 4 valved per cylinder is the best design. Thus DOHC is the best desogn. SOHC with 4 Valves per cylinder is second best. SOHC 2 Valves per cylinder is third, and 2 valves per cylinder pushrod is the least efficient.
Audi builds a 5 valve per cylinder engine, but I just don't know enough about it to comment.
Old Jul 18, 2002
ZRPM's Avatar
Dohc = Dual Over Head Camshaft
If you drive a 2K1 or 2K2 unless it's the Si or SiR has SOHC with rockers.
Why does your valve cover say DOHC? Mine says VTEC
Old Jul 18, 2002
Shawn02's Avatar
Shawn02 is an unknown quantity at this point
try the camry V6....four cams!!
Old Jul 18, 2002
ZRPM's Avatar
DOHC in V config = 2 heads = Dual over head cams per head = 4 cams
I'm not trying to BS you guys
Old Jul 18, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
Quote
[hr]Originally posted by: EvilDave666
it says dohc on my spark plug cover...i have two cams? i dont think so[hr]
Then you dont drive an EM2, if you did it should either say "HONDA" or "HONDA VTEC"...the only DOHC Civics are US Si/CAN SiR's.
Old Jul 18, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
Quote
[hr]Originally posted by: SlvrEX5spd
our engines as well as many others have 2 intake valves and 2 exhaust valves...times 4 cylinders is 16 vales and 4 per cylinder [IMG]i/expressions/face-icon-small-smile.gif[/IMG][hr]
Except for some turbo VWs and Audis, which have 5 valves per cylinder...3 intake, 2 exhaust...or vice-versa....I'm sleepy[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Jul 18, 2002
AirForce's Avatar
AirForce is an unknown quantity at this point
Quote
[hr]Originally posted by: Shawn02
try the camry V6....four cams!![hr]
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Jul 18, 2002
Shawn02's Avatar
[IMG]i/expressions/face-icon-small-confused.gif[/IMG] What's wrong w/ the camry statement??....just making an observation....and the V6 is quick...much quicker than my civic..
Old Jul 19, 2002
Quote
[IMG]i/expressions/face-icon-small-confused.gif[/IMG] What's wrong w/ the camry statement??....just making an observation....and the V6 is quick...much quicker than my civic..[hr]
Ya...I don't get it either...it IS a 4-cam motor...[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jul 20, 2002
Jon's Avatar
Jon
wait a sec, can someone explain what the 4 cam means, i'm confused?? the camry is a V6, but how does it have 4 cams....
Old Jul 20, 2002
ZRPM's Avatar
Any engine in a V configuration has 2 heads as opposed to an inline 'I' formation. Thus, a DOHC V engine will have 2 camshafts per head. So, that is why it has 4 camshafts.
Calling a camshaft a cam is a little confusing. A camshaft contains many cams. Generally 1 exhaust and 1 intake cam per cylinder. A 4 cylinder camshaft has 8 cams to actuate valves. A 4 valve per cylinder engine can use a SOHC with rockers, or a DOHC. 2 Valve per cylinder engines use either SOHC or Pushrods (in a V engine with one camsaft for the entire engine).
Old Jul 20, 2002
Shawn02's Avatar
well Jon, to be honest, i don't know the inside setup or explanation for the four cams....its my mom's car, and i just know it says "Four cam 24 and V6 3000" on the engine....i'm hopin one of the engine experts in the forum can explain it..
thebmillz
Electronics
Oct 2, 2015 08:38 PM
pilebuck13
Sep 21, 2015 10:45 PM
Jrosa
Sep 14, 2015 08:24 PM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
