bad noise from brakes
Old Jul 16, 2002
Neofusion's Avatar
Neofusion is an unknown quantity at this point
ok heres whats up... i know my rotors are ****ed up cuz i get mad vibration when i brake.. been like that for a while now. but this morning, i started the car up and when i was backing out of the garage i heard this grinding coming from my rightside front tire. sounds like metal grinding. its very audible when rolling at a slow speed (5-10mph) and i often hear it at higher speeds (40-50mph). it does not make this sound when i step on the brakes. im guessing that my brake pads are out.. will someone confirm this and how much it would cost to get it fixed?
Old Jul 16, 2002
speedracersong's Avatar
i know this should be in another section...
but what are the signs of the rotor going or the pads?
can someone tell me all this?
thanks
Old Jul 16, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
i was having the same noise after washing the car the brakes just got a lil wet (could be the same for you)
Old Jul 16, 2002
Neofusion's Avatar
nah its not cuz they were wet, i work at a car wash/detail center so i know what it sounds like when theres water in ur brakes. but still, the car has been in the garage all night so theres no way that water couldve gotten on it. the noise wont go away until im crusing past 60mph.. and it returns when i slow down.. so i definately know theres a problem.
Old Jul 16, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
ur brakepads are gone
Old Jul 16, 2002
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
basically brake calipers adjust to how thin your pads are getting, thus they are always in contact with your rotors. If you start to get a sound like that, even when you are not braking, it basically means you have no more pad left, and your brakes are metal on metal...
Old Jul 16, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
No break pads dude...You're gonna need new rotors now too. More times than not, when you get metal on metal you can't turn them within specs, so yeah, new rotors dude...
Look at it this way...Brembo here you come.
Old Jul 16, 2002
Neofusion's Avatar
new rotors too?!?! crap!! i cant afford that ish... how much am i looking at to get just my pads replaced and not the rotors??
Old Jul 17, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Go to Midas and get a free estimate. Then you will know for sure what it will take to make your car safe again. After getting your brakes fixed, have them checked more often to ensure that your pads are not running down.
Old Jul 17, 2002
man u prolly dont need new rotors theyre fine, i bought my pads for 55 bux and installed them myself, took about 30 mins per side, it was well worth it OEM Honda pads are sheit
GolNat
Suspension DIY
May 12, 2022 06:49 AM
TiggerDX
Jun 18, 2015 01:43 PM
dosmastr
May 5, 2015 12:19 PM
opticalvetc
Jan 1, 2002 08:32 PM
Sparty
Nov 15, 2001 04:55 PM
